Old 02-26-2013, 11:20 PM   #1
Groyd
Groyd's Avatar
Hood and Fender Alignment
I think the drivers side hinge is toast, is that what is causing the hood to bounce up from the fender?
The second shot is after pushing it down, but it won't stay after you hit a bump.
Second question : It sits way to high even at its lowest point, any tips for lining up the fenders and hood better?
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 02-27-2013, 02:04 AM   #2
Effeckt
Effeckt's Avatar
Re: Hood and Fender Alignment
Mine is the exact same way. I just assumed my hinges were junk. I'd be interested in knowing what others did as well if it is something different so I can fix that at some point as well.
My 1972 K5 Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=399719
Effeckt is offline   Reply With Quote
Old 02-27-2013, 02:47 AM   #3
AlaskaMatt
AlaskaMatt's Avatar
It's a spring issue or in my case the hinge was so sticky the spring couldn't pull it down. A little lube and it now goes right back down where it should.
Thanks,
Matt
My Website
AlaskaMatt is offline   Reply With Quote
Old 02-27-2013, 10:10 PM   #4
Banderian
Banderian's Avatar
There is actually a thread on here somewhere about this issue. I read it and took the advice. Fixed mine.
But, loosen the bolts holding the spring to the fender, push the front of the hood as far up as it will go and hold it. This picks up the front of the hinge and forces the back of the hinge down. Tighten the bolts. As I said, fixed mine and it looked exactly like yours.
Banderian is offline   Reply With Quote
Old 03-10-2013, 12:38 PM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
X2 It kind of pre-loads the spring so it can pull down as designed...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
