![]() Join Date: Oct 2006
60-63 vent window glass
Has anyone replaced just the vent glass ? Any tips on how to do it ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#2 | |
Re: 60-63 vent window glass
Don't know how. I'm sure it is in the FAQ or Stickies. I know I saw it here somewhere. Posted via Mobile Device
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
Not a 63 but should be close from Alan's classic http://67-72chevytrucks.com/vboard/s...d.php?t=351471 Been keeping this in my favorites for when I get to mine.
I dont know if only the vent can be removed w/o removing the glass as well, but there are two screws at the top of the door over the vent, two on the part of the door facing the cab where the vent is and two under the inner door panel to the left of the large round opening (driver side) and to the right if passenger side. These screws release the vent. I think that you have to take at least the door glass out ( remove from the window sash) to get the vent out. I say this because the door division bar is mounted to the vent.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks guys, I dont want to remove the whole vent assembly only the glass. Thanks for the link Whipingpost.
I dont know of any way to remove the glass from the vent w/o removing it. Someone else may have a solution though.
YOU CAN TAKE THE SCREWS OUT OF THE GLASS SASH CHANNEL AND LET IT MOVE ON DOWN A LITTLE. THEN AFTER YOU HAVE REMOVED THE SCREWS THAT HOLD THE VENT WINDOW ASSEMBLY, TILT IT BACK AND LIFT IT OUT. THERE IS JUST ENOUGH ROOM FOR IT TO COME OUT. YOU MAY HAVE TO ROTATE IT A LITTLE, BUT IT WILL COME OUT
Thanks for the tips. The po had replaced the right vent window with plexigalss. It is now glazed and "spider webbed" so I want to replace it. I 'll keep you guys posted .
Senior Enthusiast
Per the 1960 Chevy Truck Shop Manual, you can just pull the glass out of the frame after softening the seal with gasoline. Back in the old days I always used lighter fluid instead as it was easy to control. Don’t set it on fire just let it soak until the seal gives up its bond. I replaced vent windows several times this way on my 54 Chevy.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Don't let the EPA hear that Mark. They'll want to recall the original assembly manuals. Hahaha
Thanks Mark very cool !! 1963c-10 so true especialy here in Cali
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 03-26-2013 at 03:07 PM. |
Thanks again I was able to remove and replace the right hand side. Will do the left one this weekend
both sides are done, now I have to TRY and replace the vent window seals
