Under hood Jack Mounting question
I was courious if anyone had a picture of how the under hood jack is supposed to mount to the inner fender. (mounts on the passenger inner fender well)
1982 Chevy K10 4x4 shortbed 1978 Silverado 65 mustang fastback 68 roadrunner |
Re: Under hood Jack Mounting question
It varies slightly by model year.
I assume you are asking about an '82? Here is my '87 (driver's side mounting): ![]() Tools are located on the RH fender inner; packaged behind the coolant bottle and inserted into a hole in the battery tray. ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-25-2013 at 10:17 AM. |
#3 | |
I know this is old but hoping you, or someone, can tell me what the two pieces are in this picture; well one actually. I know one is the lug nut wrench but what is the other that is bent along with it? I'm trying to get mine set up as well. -------------------------EDIT--------------------- I see it now, it is the bent bar that goes into the jack to raise/lower it.
Scott 1982 GMC Sierra |
Thanks for the Pic. Yes mine is a 1982. Mine does not have the bracket that the jack sits in, I wonder if 82 was different or Im just missing that part..
78K & 79C Jimmys
79 pass side
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
The two bars on either side of the lug wrench are the handle for the jack. They are connected by a piece of U channel metal and two pins. You straighten the two pieces until they settle into the U channel and then connect one end into a matching hole/slot(don't remember which) to move and raise-lower the jack. The end for the jack is just out of frame toward the blower motor. The double bent piece is what you crank on to operate the jack.
