Look what I brought home today..
Today I brought home a 1965 C10. It has around 6k miles on the engine since the rebuild. It has a 4 speed manual in it and it's a bit tough to find the gears so far... hopefully it'll get better with time.
I'm pretty excited about it and I'm already making a to do list. Disc brakes, line-x the diamond steel bed, new stereo. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() Join Date: Jan 2013
Re: Look what I brought home today..
Looks like a nice start! Congratulations!
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
Nice truck!!
Posted via Mobile Device |
Who Me?
Very nice truck! Looking forward to your upgrades to it.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
![]() Join Date: Jan 2011
Nice looking truck!
I bet it is hard to find all 4 gears with that column shift...... |
Great start, I`m beginning to like long beds more and more..
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Damn that is pretty. Do you mind saying how much??
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Sharp truck! Thats a buy and drive kinda truck!
![]() John
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
Exactly. It's my everyday driver. All that needs to be done are a few light bulbs and the rest will be just customization.
However, I am a bit concerned about the transmission. It's been extremely finicky and has been tough to find the gears. The PO said he adjusted all the linkage yesterday but maybe he didn't do a very good job? |
#10 | |
![]() Join Date: Nov 2010
That is a great looking truck!! Looking forward to your upgrades!
LIFE IS SHORT HAVE FUN |
Great looking truck! Almost a Twinkie to mine!
Chris Posted via Mobile Device
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
Thanks everybody. When I bought this truck I was told that there was only 5-6k miles on the rebuilt engine. I talked to the PO yesterday and he clarified that there was SIXTY thousand miles on the engine since the rebuild... Needless to say I'm a bit upset. I took the truck to see a mechanic and he suggested for me to replace the timing chain as it is whining. He also said my engine was a bit tired.
I think that the transmission linkage is all screwed up also. Hopefully that will be an easy fix and it won't have to be rebuilt. He also butchered all the wiring. I'm tempted to buy a wiring kit from Painless and starting over. Also, depending on how "tired" the engine is I might be on the market for a new crate motor. UGH.... Any help or suggestions would be extremely appreciated. This is my first classic and finding all these demons is exhausting! |
#15 |
Also, the PO had all these cool engines in his garage. I have a feeling he put in an old motor and dressed it up a bit for the sale.
#16 |
Does the engine smoke or run bad? I wouldn't get stressed out over it. Just fix what needs to be fixed and drive it. I can imagine the 4 speed on the column (didn't even know that existed) would be tough finding gears. My 3 on the column gives me a little trouble when its cold outside. I've been looking at floor shifters, may be something that would help you too. Just because someone says the engine is "tired" doesn't mean its junk. Was probably built a little loose from the get go.
#17 |
![]() Join Date: Aug 2004
I agree with Chris^^, but if the tranny is a problem, consider putting in a 5speed, especially if you have a floor shifter.
if you have a column shifter, throw a 700 in there, either one would make a real good cruiser. clean up the motor, tune it, timing chain and drive her.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#18 |
Today I took the truck into this car shop. I pulled up and there were all sorts of classic cars setting out front. I found the right mechanic for sure. He set the timing and the idling issue I was having and the backfiring disappeared. It's running much better.
The transmission however is still giving me problems. I was sitting at a light today and the transmission started grinding. It was in neutral but still grinding. I had to turn it off and restart it to put it back in gear. Would that be linkage or synchros? Either way with a simple timing adjustment the truck is running much better. Its great to see progress even if it's small. |
#19 |
Senior Enthusiast
Welcome to the forum, your truck is really beautiful. If you're still running the original 3 speed column shifter, it's probably going to need some measure of rebuilding. They didn't work very well when new and nearly 50 years of wear makes them sloppy or non-functional. If the transmission is in good shape a Hurst shifter would solve the shifting problems, but you may not want to cut the floor especially if you are considering better transmission options available today. If you want to keep the original column shifter here are some links that may help:
This is the link that notsolo provided earlier, in a clickable version. It shows how to adjust the column linkage: http://67-72chevytrucks.com/vboard/s...d.php?t=215307 There are many other threads on column shifters, but this one has a lot of information exchange and photos on rebuilding that might prove helpful: http://67-72chevytrucks.com/vboard/s...column+shifter
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#20 | |
Thank you. My transmission is not a three on the tree. It's a Saginaw 4 speed. Do you think a Hurst shifter would still fix the problems that I'm experiencing?
#21 |
If you actually do have a 4 speed in there you're not going to be able control it with the column shifter, you will have to put in a floor shift.
#22 |
It is a Saginaw 4 speed on the floor. Not column.
#23 | |
#24 |
Maybe some pics of the floor shifter would help someone id and be able to help adjust. It's not visible in the pics as mentioned earlier. I also only see a column shift. They are fairly easy to adjust. There are a few different aftermarket shifters for floor conversions, and someone may be able to help you with some pics of it. Nice looking truck and it looks solid.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
