04-18-2013, 02:11 PM | #1 |
modified lca's (crazy?)
im keeping drum in all 4 corners so no drop spindles are availible
im trying to stay away from z'ing my frame till way later the front is bagged with plates and cups cups are 1.5" and there is already a little bag rub so i dont want to go lower i was thinking of chopping the control arm up and cupping it but... moving the balljoint up 2" basically z the control arm does this seem crazy iv got plenty of fab skill to attempt it but do you think it will mess up the geometry and performance of the suspension??? im thinking that if i do all this it willl get me to lay crossmember( an extra 5")
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
04-18-2013, 02:32 PM | #2 |
Re: modified lca's (crazy?)
It can be done as 'old school' guys did it that way once upon a time before drop spindles existed.
It will mess w/the geometry & the a-arm 'pocket' will smack something hard sooner or later & it wont be good when it happens. Why not spindles & discs to improve safety?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-18-2013 at 02:40 PM. |
04-19-2013, 10:16 AM | #3 | |
04-19-2013, 10:41 AM | #4 | |
The tires I have on it right now are 235/75r15 They are really small compared to what was on it This is aired out in the front right now Posted via Mobile Device
02-07-2015, 10:55 AM | #5 |
If your aired out in this picture something must be wrong ??? It still looks like you need a step ladder to get in the thing. Look at the next picture of the guy in the blue and white truck, that's what you should look like aired out.
02-16-2015, 05:58 PM | #6 | |
the stock wheel?
1967custom |
02-16-2015, 07:47 PM | #7 | |
The stock wheels, iv been trying to find more stock steel 6 lugs and apparently they are impossible!
04-18-2013, 02:41 PM | #8 |
Why not just cup the control arm..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
04-18-2013, 02:50 PM | #9 |
meowMEOWmeowMEOW
I think that keeping 4 wheel drums on a truck is crazy if you ever plan on driving the thing...but I hate drums.
And the fact that if you do that and crash it, your insurance company CAN drop you and sue you for the total amount of all medical and legal damages. It might seem a bit sensationalistic, but they can actually use the modified suspension as reasonable doubt of the condition of the safety and integrity of the vehicle...this is especially true if its licensed and insured as a regular or collector vehicle, without special annotations like "hobbyist, street modified, etc" in which you have additional coverage for special modifications. Not trying to stop you, but I've seen the unfortunate side of things at times.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-19-2013, 08:18 PM | #10 |
just a comparision the only thing i have done in the front is cup the lca's
1971 chevy c10 cheyenne. Bagged. New paint and some other mods. 1999 ford f350 superduty 7.3 powerstroke everything banks 1975 c10 swb "parts runner" <----SOLD NorthWest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ |
04-19-2013, 08:35 PM | #11 | |
Size of cups? Posted via Mobile Device
04-19-2013, 08:41 PM | #12 |
2500 in the front with upper plates and cupped lower control arms
04-19-2013, 09:27 PM | #13 |
yeah mine will lay x member too, with 2600's and 245/40/20's with some room to spare.
I made the cups flush with the bottom of the a arm..
04-19-2013, 09:43 PM | #14 |
Got any pics like above to see the tire tuck away?
04-19-2013, 10:24 PM | #15 |
here ya go... but yeah its about the lowest you can physically go before chopping stuff up good.
04-19-2013, 10:25 PM | #16 | |
04-19-2013, 10:26 PM | #17 |
yeah 3" spindles.
04-19-2013, 10:27 PM | #18 |
That's what I need to lay x. But then I gotta loose the inners :-( lol
04-19-2013, 10:30 PM | #19 |
yeah i had to take them out then cut into the fender to clear the tires,
04-20-2013, 02:41 AM | #20 |
That's my only downfall is I don't want to do disk, and there is not drop spindles for drum which is why I was thinking of lifting the lower ball joint
And probably pie cut the upper so the upper joint doesn't bind I know you all are thinking I'm crazy keeping drum but I'm not worried about stopping power since I don't have the tire to stop me anyways If you know what your doing drum works great I left four 20ft skid marks when someone decided to backup without reverse lights, so it stops plenty good for a tank lol I'm just trying to work with what I have and make a true ratrod Everything is homemade I take a lot of pride in my fabrication and I'm sure I can figure something out to lay xmember without major mods Posted via Mobile Device
04-20-2013, 10:06 AM | #21 | |
Happy to be here
If your going to post remarks like that, this is probably not the forum for you. We only offer advice to those that are doing everything possible to build projects to be as safe as possible.
04-20-2013, 11:24 AM | #22 |
Sorry if I came across rude, didn't mean that
My safety an everyone else's safety is fine around me 45mph to a dead stop is quick and 20 ft could have been more I only drive safe especially is crowded areas like neighborhoods My truck stops on a dime when braking is controlled Posted via Mobile Device
02-23-2015, 01:35 PM | #23 | |
To prove this I have a '64 VW with all factory manual, single circuit drum brakes. Only upgrade is it has wider/sticky 195 wide tires instead of the stock 165 wide tires. From 60 mph it will peak at .97g stopping, right at the limit of locking up. Even with the grippier tires I could still stab the pedal and lock up the front wheels if I wanted. I also have an '87 Mitsubishi Starion that has 205 and 225 wide tires, and four wheel power disc brakes and rear-only ABS. Looking back at the old Auto Week tests (and others) from when the car was new, it had some of the best brakes available when tested against the other Japanese sports cars it compared to. It also has an old set of tires that were on it when I bought it that don't have a lot of grip. The best I've been able to get is .87g max; it's much harder to keep it from locking up, and its not as easy to recover after they've locked up as the VW. We used to have a '99 New Beetle with fairly grippy 195's and four wheel discs with ABS. It would peak at .99g, only .02g better than the '64 VW with manual drums. I'm not saying disc brakes aren't good at all- they offer less upkeep and easier to change pads compared to changing shoes. From higher speeds they do better for sure. But a good drum system with good tires can be just as good (and just as safe) from normal speeds. __________________
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-20-2013, 11:28 AM | #24 |
Happy to be here
Its cool bro, thats just a touchy subject around here. I see your an auto tech by trade so you already know how important it is to address mechanical issues with safety in mind. I just encourage you to keep the same mentality you must have with customers cars and apply it to your own.
04-20-2013, 11:51 AM | #25 |
For sure bro
Safety is the biggest thing for me Which is the point of this thread, I had the idea of moving the lower ballpoint up and cupping the control arm and the issue of scrub line Posted via Mobile Device
