04-25-2013, 06:56 AM | #1 |
Name that part
These I believe came of my 2wd 75 stepside 350/350.
They match the bolt pattern on the buckets for the motor mounts but what are they for? I did clean them up but are they needed when I replace the 350 with my 468? Thanks
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
04-25-2013, 06:58 AM | #2 |
Re: Name that part
Motor Mounts
V8 Motor Mounts Not for this truck I would guess earlier model year. Thats my guess and i'm sticking to it..
04-25-2013, 07:32 AM | #3 |
Re: Name that part
They're not motor mounts, they're bracing brackets used on '88 - '98 4WD trucks. There's a rod that goes from the corner hole back to the bellhousing/tranny where it bolts in place on each side. They're in place to help brace/strengthen things since there's not a full crossmember in 4WD trucks. The engine that's in the truck probably came from a 4WD donor...or somebody used the wrong mounts and used these as spacers. You don't need them.
04-25-2013, 10:49 AM | #4 | |
Re: Name that part
04-25-2013, 08:10 AM | #5 |
At the body shop.
Re: Name that part
And a funky Newcastle.
" That didnt make it any newer " " Dont antique the equipment " |
04-25-2013, 10:52 AM | #6 |
Re: Name that part
I hate pale ale but apparently not when Newcastle makes it
04-25-2013, 11:55 AM | #7 |
Re: Name that part
Those braces were also used in square bodies. The bellhousing dust cover will be cast and it will have two bolt holes spaced approximately the same width as your engine oil pan. Pretty sure the 700R4 and the 4L80E use them.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
