Old 05-04-2013, 03:17 PM   #1
Hazieview
Building Dreams out of Dimes!
Is anyone currently running D52 rear calipers with an emergency brake?
I currently bought the D52 brackets from CaptFab but I'm struggling on how to hook up the emergency brake cable.
Has anyone successfully installed an emergency brake cable using the D52 caliper brackets? If so please post pictures.
Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 05-04-2013, 03:20 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Is anyone currently running D52 rear calipers with an emergency brake?
What part are you having trouble with? I assume all the adjusting nuts and such are loose?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-04-2013, 11:11 PM   #3
andrewmp6
A d52 is a front caliper so unless the kit uses a drum inside the rotor parking brake your only hope is a hydraulic parking brake.
Old 05-05-2013, 10:57 AM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Not always. Look up a Cadillac Eldorado rear caliper for a 1976 or so. They are D52 size calipers with a mechanical parking brake built in...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 05-05-2013, 02:02 PM   #5
mgchevyparts
mgchevyparts's Avatar
That is not a D52 caliper. That Caddy caliper uses a D154 pad, the mounting pin width is just over 5" not the 7" a D52 has.
Whoever installed that caliper has it up side down also, the bleed screw is pointing down, can't bleed it like that.
Those Caddy calipers are also very troublesome if you don't set it up correctly from the get go.
mgchevyparts is offline   Reply With Quote
Old 05-05-2013, 02:28 PM   #6
ElGracho
ElGracho's Avatar
I stand corrected. I always thought people got those rear brake kits and used either a front caliper from a truck or the rear calipers from the caddy to get the e brake.
I found these. They aren't exactly stock calipers, but the mounting points are:
Joe
Old 05-05-2013, 11:47 PM   #7
mgchevyparts
Actually, we were both right and wrong! There are Cad calipers with the wider pin to pin size, it uses a D122 pad but the dimensions seem to be very similar, if not the same as a D52, news to me.
Old 05-06-2013, 05:49 AM   #8
S10Fan
Old Heap Driver
These are a little pricey but would serve the purpose......
http://www.speedwaymotors.com/Power-...Kit,58549.html
There are also kits available that attach a rotor and caliper to the pinion.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-06-2013, 11:43 PM   #9
andrewmp6
I think ssbc has a parking brake caliper that might work.
Old 05-08-2013, 10:33 PM   #10
Gordonr1973
Home Built '87
Gordonr1973's Avatar
I got my four wheel disc set from Scott's Hot Rods --- rears have e-brake but calipers def do not match the front....about half way through my build thread.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 05-11-2013, 12:16 AM   #11
Hazieview
The 1976 Cadillac Eldorado calipers are D52 calipers. I know because i have them on the rear of my truck as we speak.
I'm just wondering if anyone has rear disk brakes with a parking brake.
SB400 350th
