Old 06-24-2003, 08:16 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Wanted...bolt loops from A pillar
Why is it that every junkyard bozo has to cut these off when they pull a cab? I have two perfect cabs with the leading edge of the bolt loops missing...arrrgg! I hate to buy a new "A" pillar just to get the front half of the bolt loop! Anyone scrapping a cab where these are good? Sorry for the rant.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-24-2003, 09:06 PM   #2
BOBSJUNKY67SBSS
I TOOK AND WELDED ABOUT INCH HALF FLAT STEEL WASHERS IT WORKS REAL GOOD BOB.
BOBSJUNKY67SBSS is offline   Reply With Quote
Old 06-24-2003, 09:15 PM   #3
stllookn
stllookn's Avatar
Bob, I was thinking of fabricating some too...for some reason I wanted it to look really stock...like anyone is going to see it down there...LOL!
Old 06-24-2003, 09:18 PM   #4
Ironhorse
Ironhorse's Avatar
stllookin, Guess I am in a fog on this one. What exactly are you in need of? Got any pics or a drawing of what you are looking for? I will be scrapping a 71 cab from a LWB that went in the ditch and rolled. Cab roof is bent, may not be any use to you. Let me know if I can help.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 06-25-2003, 10:12 AM   #5
LeRoy
Registered truck nut
LeRoy's Avatar
Let me check my inventory, lol. I cut some floor boards for patches and might have those pieces attached. I'll get back to ya
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 06-25-2003, 10:24 AM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
I believe this is the piece
Thanks GMCPaul
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-25-2003, 10:49 AM   #7
stllookn
stllookn's Avatar
CNPE, That is the piece (A pillar)...goes into the lower front corners of the cab. Mine are rock solid but the JY dogs cut the front half of the loops off instead of unbolting the front clip! I will bet if I look at a bunch of front clips I will find the other half bolted to it...LOL! I just hate to spend the money on the full part to cut it up.
I may have to buy a cordless Sawzall for the next time I go to the yard. There is one yard that will let you cut a part off their scrap for free. Problem is that it is like 50 miles from here.
Leroy...thanks for looking...I need 4 of them...but any number will help.
Ironhorse...thanks for checking as well. I only need the front half of the loop but more is fine...just cut closer to the body. Let me know what you need for them...they should fit into a postage envelope.
Old 06-26-2003, 07:34 PM   #8
Ironhorse
Ironhorse's Avatar
stilookin, Don't think you want these bolt hole pillars from either side of this cab. Both are pretty well rusted. I bought a new re-pop for my truck to use on the pass. side. Went in well and seems like OEM material. Sorry couldn't help.
Wellington, Ks
Old 06-26-2003, 08:17 PM   #9
ozarkhippie
I parted out a 72 custom camper and it had like a extra set bolted to the a pillar for extra reinforcement purposes I guess. Maybe you could find a set and bolt them over your cut ones.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 06-27-2003, 09:29 AM   #10
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Stllookn, if that is the yard in Mt Vernon come by a borrow my sawzall.
D
oldiron is offline   Reply With Quote
Old 06-27-2003, 10:37 AM   #11
progress
Gotta luv a clean shave
Thanks Dennis! No, actually, I was referring to the yard in Bermertion. Best argument I have ever seen for wireless tools though...LOL!
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up!
We make house calls too...just like the old days!
progress is offline   Reply With Quote
Old 06-27-2003, 02:28 PM   #12
StingRay
StingRay's Avatar
Your will have to go to a yard for those as they consist of an inner and an outer. The patch panel will only give you half of the assembly.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
