![]() Join Date: Apr 2003
another 1972 one ton
whats left of a 72 custom 30 with a 402/ sm465 4 spd. the engine ,trans, a/c , and most of the interior were already gone
it`s rough and wont be around here very long. none of the sheet metal is any good but it still has a few pieces on it. ign switch with both door locks $45 black door panels, they`re dirty the pass side has some scrapes on the lower front. $65 custom 30 emblems $30 V8 400 emblems $15 1 has a broke stud grill emblem $15 ho72 rear chunk 4.11 gear $175 single leg, not a no spin clutch & brake pedals $35 stainless windshield trim $30 ps sector $50. sway bar with brackets $50 softray tinted vent windows $50. pass side channel is bent. softray tinted side glass $50 all prices are plus shipping Last edited by southern parts; 06-18-2013 at 08:36 PM. |
Re: another 1972 one ton
What size is sway bar and shipping to 30530. Thanks Dale
![]() Join Date: Mar 2012
intrested in any clutch linkage left?
Is it a 157" WB or 133" WB?
![]() Join Date: Mar 2011
Interested in cab lights and wiring . How are the lenses? Price shipped to 92683. Thanks
Posted via Mobile Device |
![]() Join Date: Nov 2012
Interested in the ho72 chunk if its a posi, and front frame rails if your going that far. Let me know prices and shipping to 48030
Interested in the drive shaft if it's a 133" WB
undone- the sway bar is 1.1/16" it will be a few days before I can get it off
gmc25004X4- the only piece left is the bracket that is riveted to the frame. $10 plus shipping hard_rain420- it`s a 157" gmclonghorn- the cab lenses are cracked and crazed, looks like rats have chewed the wiring. matts customs- the chunk is not posi, how much of the frame rails do you need? pics for dirtwork |
#9 | |
If its a 2wd I need from front suspension forward. Let me know
Thanks, Sam Quote:
Interested in antenna pending pics
1972 Cheyenne (Major Project) 1993 Jeep Wrangler 2012 Ford F150 FX2 2012 GMC Yukon |
![]() Join Date: Oct 2011
how is the drivers door? any rust issues?
thanks
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
![]() Join Date: Feb 2010
I might be interested in some of the cab light lenses if GMCLonghorn isn't, even if they are crazed. I think a couple of mine are missing. Are they still in one piece? Frank
not sure if i need this for a bb swap? |
I will pass on the cab lights to fesser
#15 |
what rearend?
#16 |
crushing- no antenna , only the base.
nobolt- everything is rusty on this one fesser all the cab lights are broke. gmc25004X4- there are at least 2 different type brackets riveted to the frame. but I don't think this one is big block only. matts customs- $40 plus shipping on the frame rails. c20pickup- ho72 rearend, 4.11 gears |
#17 | |
#18 |
Could you check shipping on the differential assembly to 21771? Yeah,I know it's heavy
#19 |
the 3rd member should be about 105 pounds...if that helps
I may be interested in a roof patch with the marker light area. how bad is the lip at the top of the windshield?
#20 |
Which bearing does the HO third member have? And is the bearing in good shape? Can. You get some pics of the third member? I don't need shipping I could drive over and pick up.
87 3/4 Burb 454 49 Chev Fleetline Deluxe |
#21 |
special-k - Tim, I checked the ups website. calculated the shipping costs to be about $90. that's if the chunk weighs 105 lbs. tried the post office too, but they have a weight limit of 70 lbs. it`s still in the truck right now, once I get it out I can check the weight.
c20pickup- not a (no spin.) nobolt- the roof is rusty pics added 496bb- I cant tell you about the bearings except to say it has them. can you tell from the pic? |
#22 |
![]() Join Date: Jan 2012
Ill definitely take the rotors if they are good let me know. Ill take both saddles for sure also. Contact me to set everything up.
#23 |
I'm gonna pass on the frame rails, found them locally. Thanks though.
Sam Posted via Mobile Device |
#24 |
About 100 bucks isn't too bad. But,if it's the diff this other feller who can pick it up wants,I'll pass it on. If not,I'll ponder a bit. I'd want it for my wrecker w/5.14s that it really doesn't need these days. Thing is I'm selling it and maybe should let the next guy worry about that. I can't stop messing with it cuz I guess I really wish I could keep it!
#25 |
Interested in the screws for the marker lights if they're original and in good condition.
