62 c10 engine mounts
ive searched the forum and google and cannot find the mounts I need for my swap. im swapping a 5.3 into a 62 c10, it was a factory 6cyl truck with 3 on the tree, ive swapped in a 80s front crossmember also. I think ive seen a motor mount kit somewhere but I cant find em again.
thanks in advance
61 apache |
![]() Join Date: Aug 2004
Re: 62 c10 engine mounts
I believe you can just use the mounts/perches from the 80's model trucks, I think they are called clam shell mounts.
On my 65 I used the POL tubular perches but really could have used the stockers if I really wanted to. Oh and lets see some pix of this 62 beauty!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
How do I post pics from my phone?
61 apache |
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
So I need engine stands from the truck the crossmember came from and dirty dingo mounts? I had the 80 engine mounts at one time and they didnt look like they were going to be even close, maybe I had something wrong. But I can't find the engine stands I had so I guess I will go find some more if I need em?
61 apache |
I'm not sure if the 80s trucks had different engine stands depending on engine type, but I know the V8 engine stands from the 80s trucks will work. Just get some dirty dingo adapters and the 80s clamshell engine mounts and you're set. The only thing you'd have to dig into is whether the stock transmission crossmember will work. I know on the 67-72 trucks you just have to move it back a little and it bolts right up.
They 80s engine stands and mounts will look like this:
http://67-72chevytrucks.com/vboard//...1&d=1078173053
I'll find some 80s stands and try em again! Thanks!
61 apache |
The 80's stands are to tall for our 60-62 frames. They can be made to work with a 1" spacer under the frame side of the mount.
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135 '62 C10 SWB '03 Express Van 5.3l Dead (parting out and using motor) '99 Silverado 4.8l 5 speed 4wd |
Thanks! I thought they were to tall but I havnt had time to check for sure
61 apache |
