Attenna Mount
I'm trying to mount the antenna to the P/S cowl and am finding it impossible to get the new antenna mount to hold. I bought it from LMC (which I'll assumes gets them from a far east country) In the pictures below which show the "crown" for lack of the proper name, when I tighten the top nut which compresses the crown downward it deforms the gasket/bushing to where it slips off the crown.
In order to attempt a quick fix, I roughed up the bottom of the crown with a dremel tool and put some crazy glue to hold the gasket in place, I'l see how this works later. Anyone else have this happen?
http://s1299.photobucket.com/user/jb...23904108567829 |
Re: Attenna Mount
Chinese stuff is junk, IMO-I ended up buying an American made repro antenna off EvilBay.
Re: Attenna Mount
I used some ACC glue kak "Crazy Glue" to hold the gasket in place. Came out OK, will look for a different mount later.
You woud lthink for $89.99 you'd get something better. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=74 Part number 38-1146
#4 | |
![]() Join Date: May 2009
Re: Attenna Mount
![]() http://www.classicparts.com/searchprods.asp |
![]() Join Date: Apr 2012
Re: Attenna Mount
x2 On Classic Parts
1. They're almost always cheaper than LMC. Classic wants $64.95 for a 60-62 antenna LMC wants $89.95 for a 60-62 antenna. 2. If you order online and use "Stovebolt" as a discount code you'll get 5% off 3. Classic Parts doesn't use those annoying packing peanuts. |
Re: Attenna Mount
I got I mounted Ok after gluing the gasket on, although it leans in a bit, It will work until I find a replacement.
