Old 06-24-2013, 02:04 PM   #1
jbgroby
jbgroby's Avatar
Re: Attenna Mount
I used some ACC glue kak "Crazy Glue" to hold the gasket in place. Came out OK, will look for a different mount later.
You woud lthink for $89.99 you'd get something better.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=74
Part number 38-1146
jbgroby is offline   Reply With Quote
Old 06-24-2013, 04:05 PM   #2
Vernski
Re: Attenna Mount
Part number 38-1146
I don't know where this is made but it mounted w/no problems..Vernski
http://www.classicparts.com/searchprods.asp
Vernski is offline   Reply With Quote
Old 06-24-2013, 05:46 PM   #3
bhc41051
bhc41051's Avatar
Re: Attenna Mount
x2 On Classic Parts
1. They're almost always cheaper than LMC. Classic wants $64.95 for a 60-62 antenna LMC wants $89.95 for a 60-62 antenna.
2. If you order online and use "Stovebolt" as a discount code you'll get 5% off
3. Classic Parts doesn't use those annoying packing peanuts.
bhc41051 is offline   Reply With Quote
Old 06-24-2013, 06:49 PM   #4
jbgroby
jbgroby's Avatar
Re: Attenna Mount
I got I mounted Ok after gluing the gasket on, although it leans in a bit, It will work until I find a replacement.
