6.2 diesel feed line
ok so the main feen line on my motor is shot i think. is there any ez way to replace it with out pulling the intake?? thanks, mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Re: 6.2 diesel feed line
The hose or the pipe? The hose you can get to, the pipe's possible but a lot easier with the intake off. IIRC I had to buy a cheap line wrench and bend it, still had to take off the cruise and cable brackets. Intake removal's not too bad, just be sure the bolts go back in the same place because they are lenght sensitive. Good time to swap to a J code if you don't have one. Also a manual glow system, I took out the EFE/EGR solenoid pack and used that stud to mount the ferd relay for the glows.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
yea mine is a j code and the glow is on a toggle already. i am just going to pull the intake and fix it right on one shot
Do you need the steel line and rubber hose from the fuel pump up the block or the one on the front of the block for fuel return...I have both available would just need to find a proper box to prevent bending.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 09-01-2013 at 03:28 PM. |
48cj2a do you have a pic of the one that goes to the fuel filter?? i want to say mine has been cut. thanks
Here you go, has all the clamps and lines intact $25 + shipping
http://48cj2a.com/images/cucv/6.2/6%...uel%20line.JPG
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
thanks. but i will have to pass. just found out i am being throughn out of my house in 4 days. fml so looks like rubber house it is
Sorry to hear that...let me know if something changes and good luck!
