Well I got my 1/8th mile times
60' - 2.293
594' - 8.754 1/8 - 9.390 1/8 mph 70.83 Truck died at 3/4 the track vapor locked or something... (New to the carbed world) Left soft wheel hopped with traction bars and street tires, rolled into WOT... Drove 40 miles to track and back... What you guys think? Posted via Mobile Device |
Re: Well I got my 1/8th mile times
Oh and I was beside a new 5.0 Stang with drive out tags that I beat, he ran a 10 something it was an auto and he said he spun across the finish line he ran a 8.94 with tc on tho
Work on them 60ft times and get them down.
Otherwise looks good. What's your setup? How many leafs do you have in the rear? Shouldn't be wheel hopping. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
2 leafs... It didnt hop real bad but I have broke the trans once so I was kinda scared when I felt it..
#5 | |
#6 | |
86 c10 swb 2wd, 12 bolt rear end locker, 3.73s, th350, 355 4 bolt mains stock rods and crank flat top pistons, 64cc aluminum heads, 190cc intake runners 2.02 intake 1.60 exhaust, edelbrock aluminum intake holley 690cfm, comp motha thumpa cam, 1.5 ratio rockers, traction bars and 255/70s out back
So what model is that carb? And what fuel pump are you using? May be sucking the fuel bowl dry
At the body shop.
Whatever its worth. Mind did better with a light duty 3 leaf pack than a 7 leaf pack...
" That didnt make it any newer " " Dont antique the equipment " |
#10 | |
What causes wheel hop??
Tires wanting to get away from the ground, I would assume compression is good, just don't want rebound
| Bookmarks |
