Old 09-08-2013, 09:49 PM   #1
86c10sbc
Well I got my 1/8th mile times
60' - 2.293
594' - 8.754
1/8 - 9.390
1/8 mph 70.83
Truck died at 3/4 the track vapor locked or something... (New to the carbed world)
Left soft wheel hopped with traction bars and street tires, rolled into WOT... Drove 40 miles to track and back... What you guys think?
86c10sbc is offline   Reply With Quote
Old 09-08-2013, 09:52 PM   #2
86c10sbc
Re: Well I got my 1/8th mile times
Oh and I was beside a new 5.0 Stang with drive out tags that I beat, he ran a 10 something it was an auto and he said he spun across the finish line he ran a 8.94 with tc on tho
Old 09-08-2013, 09:58 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Work on them 60ft times and get them down.
Otherwise looks good. What's your setup?
How many leafs do you have in the rear? Shouldn't be wheel hopping.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-08-2013, 10:02 PM   #4
86c10sbc
2 leafs... It didnt hop real bad but I have broke the trans once so I was kinda scared when I felt it..
Old 09-08-2013, 10:08 PM   #5
86c10sbc
86 c10 swb 2wd, 12 bolt rear end locker, 3.73s, th350, 355 4 bolt mains stock rods and crank flat top pistons, 64cc aluminum heads, 190cc intake runners 2.02 intake 1.60 exhaust, edelbrock aluminum intake holley 690cfm, comp motha thumpa cam, 1.5 ratio rockers, traction bars and 255/70s out back
Old 09-08-2013, 10:26 PM   #6
INSIDIOUS '86
Ahh that's why. You need more leafs. Or adjust the traction bar to hit sooner. Can also run the front spring eye as high as possible to add some instant center and plant. Should be able to get 1.85 60ft times with some good traction
Old 09-08-2013, 10:30 PM   #7
86c10sbc
Thanks for the help man! I would love a 1.85
Old 09-09-2013, 12:22 AM   #8
INSIDIOUS '86
So what model is that carb? And what fuel pump are you using? May be sucking the fuel bowl dry
Old 09-09-2013, 01:23 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Whatever its worth. Mind did better with a light duty 3 leaf pack than a 7 leaf pack...
Old 09-09-2013, 01:48 AM   #10
INSIDIOUS '86
I'm sure it did. Mine has three and doesn't hop.
Old 09-09-2013, 03:31 PM   #11
Rich84
Rich84's Avatar
What causes wheel hop??
Rich84 is offline   Reply With Quote
Old 09-09-2013, 03:34 PM   #12
86c10sbc
Tires wanting to get away from the ground, I would assume compression is good, just don't want rebound
