Old 09-11-2013, 02:07 PM   #1
csdineley
csdineley's Avatar
trans stuck to engine?
Hello
Trying to pull my th400 from my 350. Everything is removed. I double, triple, and quadruple checked! Tried wiggling it left and right, up and down. It doesn't even move a mm to get a pry bar in between. Any tips or tricks??
csdineley is offline   Reply With Quote
Old 09-11-2013, 02:10 PM   #2
walkerb
walkerb's Avatar
Re: trans stuck to engine?
Loosen the crossmember and/or remove trans mount and wiggle the back of the tranny.DOH! wiggle the back of the 400
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-11-2013, 02:14 PM   #3
csdineley
csdineley's Avatar
crossmember is removed, and tried wiggling in all directions. Still hasn't moved at all.
Old 09-11-2013, 02:20 PM   #4
walkerb
walkerb's Avatar
What about carefully jacking up on the back of the tranny to help break it loose?
Old 09-11-2013, 02:23 PM   #5
csdineley
csdineley's Avatar
Tried that also. I've removed many transmission over the years and never had one that wouldn't come out. Been trying for 7 hours now.
Old 09-11-2013, 02:31 PM   #6
nheller76
nheller76's Avatar
Try taking the Torque converter bolts off. My old tranny jammed itself into the torque converter and I had to do this. Is your starter off, I know dum question but that might be gumming things up too.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 09-11-2013, 02:44 PM   #7
csdineley
csdineley's Avatar
Starter and Torque converter bolts are removed.
Old 09-11-2013, 02:51 PM   #8
csdineley
csdineley's Avatar
How about heating it, Good or Bad?
Old 09-11-2013, 02:55 PM   #9
walkerb
walkerb's Avatar
Trying to reuse the 400?
Old 09-11-2013, 02:58 PM   #10
walkerb
walkerb's Avatar
what about prying down at the back? 2x4 on cab floor and then pry down?
Old 09-11-2013, 03:01 PM   #11
csdineley
csdineley's Avatar
No not trying to reuse it, but would like to sell it after wards. And haven't tried that one yet. I'll go give it a shot.
Old 09-11-2013, 03:22 PM   #12
csdineley
csdineley's Avatar
It worked, Thanks a million!!!
Old 09-11-2013, 04:42 PM   #13
jimboh247
jimboh247's Avatar
Walkerb,
Where were you 7 hours ago?
LOL!
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 09-11-2013, 07:22 PM   #14
walkerb
walkerb's Avatar
I'm glad it worked man. Now sell me some rust free NC body parts! Hahahahaha
