Can you replace the mechanical oil nipple on block?
Okay well i had to replace the old nylon oil hose , because itrubbed against the linkage and was spraying oil
I went to autozone and got their copper line kit, i disconnected everything, cut the line, put everything that needs to be on the line, screwed the long fitting first, then went to screw on the fitting to the engine block nipple? and it wont tighten snug, its on the thread i can feel it, but not snug, i think it may be stripped, can you replace these nipples, havent had a chance to look at it VVV click its a video ![]()
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
Re: Can you replace the mechanical oil nipple on block?
Maybe it's a different thread. Pipe thread is different than the thread on a flare fitting
I got this one from autozone, but it came with copper tubbing
http://www.autozone.com/autozone/acc...er=131456_0_0_ O great i didnt know they have different pitch threads...
You have 2 different adaptors there. A male pipe to your tubing nut and a female pipe to your tubing nut. Use the one that fits on your motor.
OMG I didnt even notice that, its a good thing i didnt throw them away, thanks for your insight, im going to try and fix it after work
