Old 10-28-2013, 11:04 PM   #1
Chrisxeasy
Chrisxeasy's Avatar
C10 C-notch finished process
Here is my process for my 75 c10 c notch process also has a axle flip kit and 2" lowering shackles
Chrisxeasy is offline   Reply With Quote
Old 10-28-2013, 11:05 PM   #2
Chrisxeasy
Chrisxeasy's Avatar
Re: C10 C-notch process
Photo two, bracket cut out
Old 10-28-2013, 11:07 PM   #3
Chrisxeasy
Chrisxeasy's Avatar
Test fitting and drilling bolt holes
Old 10-28-2013, 11:08 PM   #4
Chrisxeasy
Chrisxeasy's Avatar
Install bolts and washers and tighten
Old 10-28-2013, 11:09 PM   #5
Chrisxeasy
Chrisxeasy's Avatar
C notch finished and 2" drop shackles installed
Old 10-28-2013, 11:11 PM   #6
Chrisxeasy
Chrisxeasy's Avatar
Inside view of finished bolt on mcgauheys c-notch
Old 10-29-2013, 12:02 AM   #7
mongoose
mongoose's Avatar
Re: C10 C-notch finished process
looks good on the notch... but what's your pinion angle set at? looks a bit steep...
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 06-08-2014, 11:31 AM   #8
JP238
JP238's Avatar
I noticed you only have to leafs on your springs. What is the ride quality like? And do you have plenty of travel with the notch?
JP238 is offline   Reply With Quote
Old 06-09-2014, 09:23 AM   #9
blazer2007
are hangers on backwards ?
blazer2007 is offline   Reply With Quote
Old 06-09-2014, 11:52 AM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
I'd flip the shakles around...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
