Old 10-31-2013, 08:48 AM   #1
67Slider
67Slider's Avatar
Steering Column Swap?
Will a steering column from a 67 c10 swap into a 65 c10? I couldn't find anything on the search and a buddy wants my old steering column if it works. I figured I would ask here and get the skinny.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 10-31-2013, 09:35 AM   #2
kieth
kieth's Avatar
Re: Steering Column Swap?
I think most of us trade columns for a tilt instead of stock to stock, that is why you are not getting any info....... Kieth
kieth is offline   Reply With Quote
Old 10-31-2013, 10:19 AM   #3
67Slider
67Slider's Avatar
I think he is wanting to move his shifter to the floor without going tilt.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 10-31-2013, 10:55 AM   #4
hopped up
hopped up's Avatar
think the collum in my 64 is from a 67-72
hopped up is offline   Reply With Quote
Old 10-31-2013, 11:44 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
It's not a direct bolt-in due the emergency brake bracket on the 60-66 trucks. This bracket does a combination of things, it's secures the E-brake assembly and it also becomes the lower attach mount of the column. You can use a 67-72 column, but you have to weld the column tube nutplates from the 60-66 column into the 67-72 tube. These nutplates are the lower attach points for the column.
I was originally going to use a '68 column in my '64, and I modified the '68 column tube to work, but i wound up finding a '65 automatic column. I have the modified tube in my parts stash. All one would need to do is disassemble the 67-72 column and swap tubes.
If you use the later column, you have a few options on the shaft section between the column and the gearbox. One, you can use the '67-'72 section, and it should work. Two, you can get the parts (u-joint, section of 3/4" D-D shaft, gearbox shaft adapter and rag joint) and make your own. Three, you can use a section of your original '65 shaft and buy a combination u-joint that goes from 3/4" D-D to 3/4" -36 spline.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-31-2013, 11:46 AM   #6
NEWFISHER
NEWFISHER's Avatar
I welded the 2 nuts onto the tube and re-used the ebrake cradle/bracket. Going from 65 to 74 the lower section was too short so I used some square tube as a slip and welded it together once mounted.
NEWFISHER is offline   Reply With Quote
Old 10-31-2013, 02:36 PM   #7
67Slider
67Slider's Avatar
Thanks for the replies gents. This will help.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
