Old 11-01-2013, 10:02 AM   #1
BOXER957
BOXER957's Avatar
HELP! turn signal install...wtf..where do they go?
OK so I took apart my steering column, making sure to take pics as I went. The problems I'm having are..for some reason the pics are awol and I cannot find an exploded view or diagram that show where these little jump out of somewhere pieces go. I know I'm not that much more efficient than the factory, so....HELP!! Where do they go....anybody...Pics would be so helpful but I can try to follow instructions. ANY help would be much appreciated.
Nice EASY project, no problem....until I get home why is that? My build: http://67-72chevytrucks.com/vboard/s...d.php?t=595078
BOXER957 is offline   Reply With Quote
Old 11-01-2013, 11:32 AM   #2
BOXER957
BOXER957's Avatar
Re: HELP! turn signal install...wtf..where do they go?
I checked out all areas of "FAQ'S" and Hilandrs' link and then some. I cannot find ANY info on where these two pieces go. I just bought the part to repair the broken blinker switch, ended up taking the whole column apart for other reasons. Does ANYBODY know what these parts are and where they go? Or do I just have to buy a whole new switch kit and wire it in?
Old 11-01-2013, 12:06 PM   #3
LVPhotos
LVPhotos's Avatar
I found These... I always point toward the Yellow Book(Factory Assembly)
http://67-72chevytrucks.com/vboard/s....php?p=4551646
http://www.gobookee.org/search.php?q...+column+repair
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-01-2013, 12:20 PM   #4
BOXER957
BOXER957's Avatar
I had those printed out before I started this fiasco, unfortunately nothing shows the turn signal switch and/or that little plastic piece. Thank you though for trying!
Old 11-01-2013, 12:53 PM   #5
BOXER957
BOXER957's Avatar
OK I know where the brass ring goes, but where does the little plastic dohicky thing go????????????
Old 11-01-2013, 01:25 PM   #6
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
First off, you need to use the right terminology!! That is obviously not a dohicky. It is most definitely a thing-a-majing... LOL
I recall having about the same problem with my son's truck, but luckily we had pictures. I will try to remember to look when I get home. Good luck until then!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 11-02-2013, 04:49 AM   #7
BOXER957
BOXER957's Avatar
Now I could be wrong, but I always thought a thing-a-majig served a purpose, you knew what that purpose was but just couldn't think of the name. A dohicky was always one of those oddball little things that you stand there scratching your head wondering what it is, where it came from and is it reeaally necessary to put back....That being said, I do believe I have the right term...then again I have been wrong before...just ask my wife
Old 11-02-2013, 11:06 AM   #8
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Originally Posted by boxer957 View Post
now i could be wrong, but i always thought a thing-a-majig served a purpose, you knew what that purpose was but just couldn't think of the name. A dohicky was always one of those oddball little things that you stand there scratching your head wondering what it is, where it came from and is it reeaally necessary to put back....that being said, i do believe i have the right term...then again i have been wrong before...just ask my wife
lol
Jason
Old 11-01-2013, 04:23 PM   #9
forestb
forestb's Avatar
What year of truck. I just rebuilt a 64 gmc column and that plastic peace does not look at all familiar.
forestb is offline   Reply With Quote
Old 11-01-2013, 07:35 PM   #10
BOXER957
BOXER957's Avatar
I'm working with a 66...you may not have seen anything like it because it jumps out of wherever it goes and bounces around...I just happened to see where it went, not where it came from. I'm about ready to consider myself more efficient than the factory...for now. The blinkers seem to lock on ok, they click off when I turn the wheel...whether or not they work I won't know until I get the truck back together again and have power going to them. Until then..if anybody knows, by all means enlighten me
Old 11-01-2013, 10:34 PM   #11
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Well, finally made it home, but cannot find the pictures. I found the ones where we took apart and repaired the one in my '60, but that is a whole different animal. If I get some time this weekend, I will pull his apart again and see.
Good luck!
Jason
Old 11-02-2013, 04:37 AM   #12
BOXER957
BOXER957's Avatar
Good luck!
60 is all different 64 to 66 would be the same. Thanks you though for the offer. Judging by the amount of feedback I'm getting I think this will forever be a mystery. Most likely though someone will decide to answer as soon as I'm done washing my hands after finishing putting the column together
Old 11-05-2013, 09:38 PM   #13
BOXER957
BOXER957's Avatar
Anybody??
Old 11-06-2013, 06:57 PM   #14
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Protesting a little at work today, so have been digging all over the net looking for something for you. I should actually get off work on time today, so hopefully be able to take apart my son's column and get a look at it. I didn't find anything at all that even looked similar to what you have. Are you positive it is a stock column? Maybe post a pic or two of the column, and someone smarter than me could help.
Jason
Old 11-06-2013, 08:17 PM   #15
TommyDuncan
I just had my 62 GMC apart and it was completely different. Sorry no help.
Those parts look familier though...I also have a 63 Nova. Maybe they are the same?
If you are still stuck tomorrow I can look at the library here. They have a good reference section.
TommyDuncan is offline   Reply With Quote
Old 11-07-2013, 11:11 AM   #16
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Boxer957, I took apart my sons steering wheel last night, and it does not have those parts in it. I took pics, but didn't end up with time to get them on here. It has this in the column.
Jason
Old 11-07-2013, 11:35 AM   #17
BOXER957
BOXER957's Avatar
I really appreciate your time and effort trying to figure this out. At this point I'm just going to let it go the way it is. When I get it running if something doesn't work I'll worry about it then. I just figured someone might see it and know exactly what it was when they saw it. Once again thanks so much for taking the time to try and figure it out.
Old 11-12-2013, 01:17 PM   #18
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Just saw this picture this morning, apparently we were both right! LOL
Jason
Old 11-12-2013, 04:24 PM   #19
BOXER957
BOXER957's Avatar
Well , there we have it. If it's on the internet it must be true!
Old 11-12-2013, 04:31 PM   #20
1963c-10
1963c-10's Avatar
Can you post a pic of your column? Those parts do not look 60-66 and I believe your column may have been replaced by the PO.
1964 Short bed trailer
Old 11-30-2013, 12:26 AM   #21
Dillon Rock
In the words of Bill Engvall, "Here's your sign".
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline   Reply With Quote
Old 12-06-2013, 03:25 PM   #22
TheDark1
Intentionally Left Blank
TheDark1's Avatar
I think that's the "toggle" for the turn signals. I don't know what else to call it. I believe it goes between the two halves of the indicator switch assembly. When you pull the turn signal lever down, the plastic pin pushes two of the metal contacts apart while pushing two together. Or something like that.--Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 12-06-2013, 03:56 PM   #23
BOXER957
BOXER957's Avatar
Screw you Jeff!!! Now I have to take that hole thing back apart just to check and see if you're right !?!?.......Just kidding, thanks for the input but I probably lost that little piece by now.....now that I may actually know where it goes.....figures..
Old 12-06-2013, 04:05 PM   #24
TheDark1
TheDark1's Avatar
HAHAHAHAHAHA! My eyes are watering from laughing. Sorry for the late reply, though. I haven'y been on here much the last few months. I'll try to find a picture and see if I'm right. Or I might have my old switch somewhere. My garage is a mess. LOL
1997 Formula WS6
Old 11-01-2013, 10:45 AM   #25
BOXER957
BOXER957's Avatar
Originally Posted by Woogeroo View Post
You should try reading this sometime :
60-66 faq index
but for your immediate issue:
section 3, external links, 60-66 truck sites:
hilandr451 60-66 chevy truck site has a tutorial about replacing the whole switch.
-W
I searched everywhere! I always search the forum before I ask for help, I don't want to be a pain in anyone's backside. If I search and it doesn't come up I can't read it though. Thank you for responding and I will try and find both leads.
