11-17-2013, 09:51 PM | #1 |
Blew it
i blew out my inline 6, i'm now looking for a replacement motor. looking for a 305. any suggestions?
11-17-2013, 10:08 PM | #2 |
Re: Blew it
Why a 305? May as well go 350 in my opinion.
11-17-2013, 10:14 PM | #3 |
Re: Blew it
I was thinking about going that route too, I wanted to save some gas by going with a 305
11-17-2013, 10:21 PM | #4 |
Re: Blew it
check craigslist, sometimes there good deals out there, i found myself a 305 complete for $150
11-17-2013, 10:20 PM | #5 |
Re: Blew it
MPG difference between a 305 and 350 will be negligible in factory form.
11-17-2013, 10:31 PM | #6 |
Re: Blew it
What are some of the major changes that I'm going to need to make for this switch?
11-17-2013, 10:53 PM | #7 |
Re: Blew it
when i installed mine i installed new motor mounts, and a new flywheel also oil pan gasket,
thats about it, all wiring is almost the same, u will need new exhaust, power steering pump is different, mine came with the original pump for the 305 so i didnt have to buy it,. besides that thats about it |
11-17-2013, 11:00 PM | #8 |
Re: Blew it
What did you pull that out of?
11-17-2013, 11:02 PM | #9 |
Re: Blew it
1976 Chevy silverado,
11-17-2013, 11:02 PM | #10 |
Re: Blew it
Mine is a 1982 Chevy custom deluxe
11-17-2013, 11:06 PM | #11 |
Re: Blew it
sure go 305! 6 cyl power with v-8 mileage
"DON'T TOUCH THE TRIM!!"-Early Kyler |
11-18-2013, 12:10 AM | #12 |
Re: Blew it
I pulled my factory 84 250 L6 with a 3 speed manual tranny and put in a 74 305 just used the motor mounts and wiring harness out of the 74 ( everyhting plugged in perfectly). the flywheel and bell-house bolted up perfectly from the L6 nothing else needed to be changed just hook up and go.
on a side note my truck had no power options(brakes,steering etc..)or a/c so only had min to hook up.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
11-18-2013, 09:37 AM | #13 |
Re: Blew it
305 is a good motor. Not as powerful as a 350 but a good motor none the less. My truck had one (305) swapped in before I got it and right now im focusing on tightening it up/fixing leaks but in the long run I am building a vortec 350. It's all about what you'll be using it for.
What will you be using your truck for?
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
11-18-2013, 09:39 AM | #14 |
Re: Blew it
Your in Texas so hills shouldn't be a problem... 305's HATE hills lol
11-18-2013, 10:13 AM | #15 |
78K & 79C Jimmys
Re: Blew it
I'm using a stock 79 2B-305 (some carb issues,not block)
runs great otherwise i've abused a few over the years,depends how they were maintained too check harness wire length,and wire spot in harness
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-18-2013, 11:33 AM | #16 |
Re: Blew it
I'm mainly gonna be using it on the weekends. Does anyone recommend a 305 crate? I don't want to spend 2 to 3 thousand on an engine but 1,500 wouldn't be bad. I figure I would be spending that much money fixing up a used engine
11-18-2013, 12:11 PM | #17 |
Re: Blew it
a 305 or 350 will both be a bump up. both engines will produce better torque bands which you will enjoy. it would be nice to use a 350 vortec but its not as plentiful as the pre 96 model. the vortec 305 isn't much different than the previous models. as for a crate engines, 305's are well priced and the tbi 350's are in the 1200-1500 range. I do suggest a full tune up if you go with a used engine
11-18-2013, 12:19 PM | #18 |
Re: Blew it
11-18-2013, 12:20 PM | #19 |
Re: Blew it
Do you guys recommend a crate to get?
11-18-2013, 12:30 PM | #20 |
Re: Blew it
Have you searched the classifieds here on the board? I recall 2 different sbc's that were listed recently for around 1K.
11-21-2013, 10:07 AM | #21 |
Re: Blew it
I'm still doing some searching but haven't had anything to my liking. Craigslist, eBay, classifieds no luck. The search will continue...
11-21-2013, 10:57 AM | #22 |
Re: Blew it
I have don this swap many times, I always found a good running donor car and used everything from that. Pulled engine as complete as possible and slid it in.
69 Chevy C10 Fleetside Long box |
11-21-2013, 11:01 AM | #23 |
Re: Blew it
you can have great gas mileage/hp if you go with a ls swap. a 5.3 will be perfect. i screwed up on no going that direction
11-21-2013, 05:21 PM | #24 |
why not swap in one of these
GM warranty and everything.
BRAND NEW http://www.summitracing.com/parts/na...7353/overview/ Cant beat em. Well, you can, but not by much....... |
11-21-2013, 06:07 PM | #25 | |
Re: why not swap in one of these
