Pictures of exhaust on bagged trucks
I am looking for exhaust ideas on running the exhaust with a C-Notch in the rear.
Please post your pictures Thanks Jim |
Re: Pictures of exhaust on bagged trucks
4" . Just kidding that's my diesel left overs. See my build page. Stupid cardomain page is jacked now.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
ok after correcting size here ya go. This is a '62 frame. The muffler guy welded the bar across top for the muffler hangers and the pipes run side by side no x or H pipe connection. Not needed unless over 500hp. Flowmaster Delta 40s Loud and proud when on it, mild while cruising. No drone.
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
NO NOTCH BUT BAGGED REAR...
CLICK ON THE OTHER THUMBNAILS TO SEE MORE PICTURES OF THE EXHAUST: http://kieth.smugmug.com/Trucks/66-GMC/i-HrvtMh3 |
take a look in my thread, have a pretty good notch in the rear
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
Jason |
![]() Join Date: Mar 2013
I'll say one thing...On a lowered truck...the exhaust has to be a hiiiiiiigh up as possible! LOL! Or you might go over a bump and watch the exhaust go out the back of the truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
'58 Apache |
#10 | |
I like all the set-ups pictured.
Anyone else have pictures? I went to a custom exhaust shop and talked and showed the owner, where I was putting the 4'' hole with welded in 4'' pipe reinforcement in the trailing arm member. The owner said it would not be possible to bend it up within the frame because of the stock tranny cross bar. What do you guys think, also pictures of this area on your so I bring them in and show him. Thanks Quote:
Thanks |
Heres a few of mine, starts at the 292 and goes outside the frame, both go under the driver seat, one crosses over behind the cab, and both follow the frame all the way out the back.
Looks like Jdoisher took the same route but with a V8, Nice looking work bud! I love that setup , I didnt notice any heat or noise issues at all, Ill do it again for sure, But next truck is gonna have 18 inch treads in back so Ill have to run between the rails on that one,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp Last edited by 64chevtruck; 03-10-2014 at 05:53 AM. |
last one, gonna install a flamethrower soon.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp Last edited by 64chevtruck; 03-10-2014 at 05:49 AM. |
