Old 12-22-2013, 09:12 PM   #1
smogrods
New guy here... quick question for the pros
hey every one ive been lurking for a few weeks now and i came across something weird on my c-10.
I bought this 1970 c-10 lwb in oct
and have been tinkering on it getting it to a reliable driving state since. ive been rewiring the entire truck.
well when i was under it today i noticed it has 2 fuel tanks one in the cab and one under the bed.. as well as a selector switch that i only assume is a tank selector on the floor.
where is the fuel filler for the under bed tank?
please see my pics.
here is the tank selector switch (i think)
the cab tank
some shots of the under bed tank
some shots of the side of my truck.
smogrods is offline   Reply With Quote
Old 12-22-2013, 09:24 PM   #2
Tinkermc
Re: New guy here... quick question for the pros
bet it fills from the tank in the cab, but if you work like a snake you can follow the filler neck if there is one.
Tinkermc is offline   Reply With Quote
Old 12-22-2013, 09:44 PM   #3
Hawghauler
Hawghauler's Avatar
Sometimes with the underbed tanks, they put the filler in the bed. Sometimes in the driver's side tail light, sometimes in the driver's side rear clearance light, sometimes behind the rear license plate, and sometimes inside the rear wheel well. I'm surprised the PO didn't inform you of it's location.
It may be that he was in the process in installing the underbed tank, and wasn't finished yet.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 12-22-2013, 10:25 PM   #4
ole dollor
ole dollor's Avatar
that would be good if you could find the filler , and use it....
ole dollor is offline   Reply With Quote
Old 12-22-2013, 10:49 PM   #5
smogrods
the p/o didnt know a damn thing about this truck. i bought it and he said he never had it running i pulled a valve cover and the heads looked brand new so i ran a # came back as a world motown cast iron head... so i thought id pull a head to see if the 350 was bored and its a brand new never fired 400 stock bore so i drained the pan and there is no oil in the motor even.
Old 12-23-2013, 12:49 AM   #6
Terry Crist
By looking at your pictures I can see what looks like a filler hose running to the drivers side. Just follow it and see where it goes.
Can you see any wiring coming from the top of the underbed tank. If so, there should be an electrical switch to switch the fuel gauge from one tank to the other. The switch could also be hooked up to the tank transfer switch that you show in the cab.
If there is no switch for the fuel gauge there might be an electric fuel pump to transfer the fuel from the underbed tank to the tank behind the seat.
Also the underbed tank could be the only one hooked up and whoever added the tank never removed the in cab tank.
Looks like follow the yellow brick road time.
Terry Crist is offline   Reply With Quote
Old 12-25-2013, 12:24 AM   #7
swamp rat
swamp rat's Avatar
Could be a marker light fill.. Try and find an inlet hose/tube and see where its terminated. Could also be a non finished project.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-25-2013, 11:01 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: New guy here... quick question for the pros
From the picture it looks like it is in the fender well on the backside of the truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-25-2013, 01:48 PM   #9
Tinkermc
Did you find it yet?
