![]() Join Date: Jan 2014
1970 Outer Tie Rod End
I am replacing the outer tie rod end passenger side on my 70 C10. This truck does have front disk brakes. I purchased the a Moog outer tie rod for it. Whenever I got the old one off it does not match the new one. The OD on the old one is larger than the new one. We went back to the parts store and looked at all tie rod ends thru 1987 and nothing matched. Thread on the old one is 1/2 20. Any ideas?
![]() Join Date: Aug 2004
Re: 1970 Outer Tie Rod End
63-70 are one size, 71/72 are yet another size and 73-87 are yet another size. If yours are larger than your 70's then I would suspect you have a 73-87 spindle on there, just because 71/72 aren't prevalent and I would think you would know it. 73-87 tie rods have the largest threaded end.
Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
67-72 parts collector,…
![]() Join Date: Nov 2002
63-70 OUTER tie rods are 5/8" LH thread.
71-72 OUTER tie rods are 11/16" RH thread. 73-87 OUTER tie rods are 11/16" RH thread. Someone has changed parts in your front end. Pics would help. The tie rod has to match the spindle year.
I figured the previous owner used 73-87 parts for the conversion. But the length of the tie rod and size of the thread match none of these. I bought everything for a 70 outer, inner and sleeve to see if this will work.
#5 | |
The only way they will work with a disc brake spindle is if someone used aftermarket 63-70 disc brake conversion spindles. You have to figure out what year spindle is on your truck!
Bottom tie rod is the one off the truck. The new tie rod is for a 70.
#7 | |
Inners, outers, sleeve, centerlink, and spindles all have to match.
Is it possible that it's from a larger truck, 3/4 or 1 ton? I don't know but if the OP knows it's a 73-87 conversion then maybe it's a possibility?
Anthony '67 Shortstep (555/T56) '67 Parts Truck (TBA) |
Sorry, I misread your other post. Thought you said you figured out, not just figured. Pictures will be the only way to tell what crossmember and spindle you have.
How about some pics of your suspension under the truck?
i will snap some pics of the suspension. The 71-72 was alot longer than the one off the truck.
Passenger spindle
Steel a-arm bushings or rubber a-arm bushings?
#15 |
Rubber
#16 |
Hollister Road Co.
rubber makes it at least a 73. If you can give me the measurements I can cross it and see what number it is.
I would need the length from the thread end to the center of the stud, usually the grease fitting is in the center, thread size, the small diameter of the taper and the large diameter of the taper. |
#17 |
Yep,... 73-87.
There's only one 1/2-ton outer tie rod that I know of.
#18 |
Pic of the drivers side
#19 |
2WD versus 4WD?
#20 |
2wd
#21 |
Sorry, I meant your swap parts. I looked up C10-C30 and it was all the same part#. When I got to C50-70 it was different and the 4WD stuff was different as well. Taking measurements for Dave will hopefully get you what you need.
#22 |
Here are the measurements I came up with using a mic.
Top of Taper-0.6310 Bottom of Taper-0.509 The threads mic at .65 Length to center of stud 6 1/4 |
#23 |
Hollister Road Co.
Are the taper measurements on the taper? not on the threads or the straight part at the bottom 509 and 631 don't match to anything that's 6.25 long or +/- .50"
Threads are 5/8 |
#24 |
Hollister Road Co.
I did find a ES678 6.62 long, 5/8-18 with 0.516 top 0.627 bottom taper for a 63-64 C10 it has a right hand thread and its an inner.
RS323L and RS323R are the outers but only 4" long with the same taper and threads. all for 63-64 possibly the tie-rods are flipped end for end? |
#25 |
I think the previous owner just used what he could find and did not use the correct parts.
