01-23-2014, 05:54 PM | #1 |
front end question
I have a 69 short bed and I have replaced everything in the front end except upper and lower control arm bushings. my problem is truck road walks on me, do you think new bushings could fix this issue. thanks in advance
01-23-2014, 07:04 PM | #2 |
Re: front end question
Likely yes. But tires will also cause this. Check your tires real well for belt separation.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
01-23-2014, 08:04 PM | #3 |
tires are brand new and I have rotated them with no change in handling thanks for your reply
01-23-2014, 08:29 PM | #4 |
You will also need to have it aligned. If the alignment is off it will walk and dart all over the road
01-23-2014, 08:30 PM | #5 |
Eat, Sleep, Drive a Chevy
First let me say welcome to the board!'
Have you had the front end alignment checked after you changed all the parts? Even if it was close before you now have removed any slack in the steering linkage, It will need to be re aligned to be correct. also check the steering gear box for any excess slack. Good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
01-23-2014, 09:18 PM | #6 |
yes I had it aligned after replacing all parts. the steering box is new also
01-23-2014, 09:31 PM | #7 |
Is your truck stock height or has it been lowered? If lowered, how was it done?
01-23-2014, 09:42 PM | #8 |
it has 2 1/2 drop spindles
01-23-2014, 09:47 PM | #9 |
Lets see that alignment print out! Toe will make that thing steer all over the place especially when there are errors in the pavement. It will follow every bad spot in the road. Seems every since I got into throwing down on GREAT alignments for these trucks every truck has left the rack with a lot to be desired and little to show for the money spent.
If nothing else, show us how bad those bushings are.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
01-23-2014, 09:52 PM | #10 |
I didn't get a print out all I know is it was in the green on tire wear machine
01-23-2014, 09:54 PM | #11 |
also he told me upper and lower bushings had some slack but wants 700 bucks to replace them ouch
01-23-2014, 10:49 PM | #12 |
The upper and lower bushings on these trucks are STEEL. So if there is any slop what so ever there will be no way to get the alignment correct. The bushings are not that hard to change. you can do it.... We can help
01-23-2014, 11:03 PM | #13 |
thanks for all the advice guess I will try and change them myself and have realigned
