Tall valve cover questions
I have been building a 350 small block out of a 69 gmc sierra grande I have run into an issue the stock valve covers were cracked so I bought a set of nice finned corvette covers they are tall unlike the stock ones now I can't get the alternator off is there a different bracket I need? Any one run into this
Re: Tall valve cover questions
Motor picture
![]() Join Date: May 2010
I've read on here that the 72s have longer adjusting arms that may solve your problem.
I just noticed that you are in Queen Creek. Send forum tkorinek (Tom Korinek) a PM and ask if he has one. He's in Mesa and sells on the parts board and local swap meets. Here's an old thread with a picture. http://67-72chevytrucks.com/vboard/s....php?p=1205530 Last edited by FirstOwner69; 02-19-2014 at 11:33 PM. |
Thanks first owner
No problem. The Corvettes also had longer braces/ arms. Here's a link to Corvette Central. I searched the 63-67 years for "alternator brace". They look even longer. Be sure to select a left side brace if you have your alternator in the original location. If they are too long, you can always shorten them and re-drill the hole.
http://www.parts123.com/parts123/yb....rt~A2~cadefibB |
So if I find a 72 bracket you think it will make up for the tall covers?
You'll probably want both lower/upper brackets for the corvette ones. I had the same trouble, though we just relocated the stock bracket (top) and got a longer belt. There are pics in my thread.
project: "my happy mess" |
So the solution ended up being I bought a belt for a 72 instead of a 69 removed my valve cover that allowed alternator to loosen enough to put belt on then tightened alternator in place then put valve cover back on everything seems to work we will see when I put engine back in
