pinion angle? level truck?
Hello once again ...i know my truck needs to be at ride hight to set pinion angle ..but does my truck have to sit level. im working on a unlevel floor. and once again thanx to everyone for building my truck...
Last edited by ooimpalaoo; 02-27-2014 at 03:49 PM. Reason: because i cant speeel |
Re: pinion angle? level truck?
Do you have the trans in? If so just match the trans angle with the pinion angle.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#3 | |
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
yes tranny is in ...so i dont need dto have the frame level? just at ride hight and set/weld?
Hollister Road Co.
pinion angle is about the angles between the trans, drive shaft and rear. You could do it on a hillside it doesn't change the drive shaft to pinion angles.
What does matter is it the ride height being where you want it and is it at the curb weight you want. Don't set it and then decide to put the 800 lbs bed on it. |
Trans output should be around 3 degrees down and pinion should be the same angle only pointed up, with the frame at ride height. Usually the frame is level at ride height unless you live in Kentucky and drive a ford
maybe.
at ride hight my tranny is at +5 so do i set my pinion at -5 ?,oh and my truck has 2 shafts..sorry
Can you raise the tranny a bit to get it closer to -3?
the motor and trans are bolted down.. i added air bags and so i have a diff ride hight.. can i add i shim to the rear trany mount to raise it?
Yep. Probably only need 1/2 an inch
i was driving this truck on bags. then did the rear swap to a five bolt. the trany was in the spot it is now and it was great down the road..
just want to get it back on the road because i start a new job in 4 days..need to weld her up tomorrow..i hope
just found this ...look right?
You have a one or two piece drive shaft?
#15 |
2 piece. oh and thanx for the help tinydb84
#16 |
All the info before is based on a one piece. Mine was 4 down and 4 up in the rear. The driveline was 6.5 for the first and second piece. Both pointing down to the rear.
#17 |
ive heard that the rear should be down because when driving it will rise.. as of now my front is +5 and my rear is -5.. the shafts look like a V from the side.. just like the pic
#18 |
Hollister Road Co.
#19 |
yes i have the stock trailing arms...so what do i want to do?
#20 |
| Bookmarks |
| Tags |
| air bag, c10 2wd fleetside longbed, level, pinion angle, ride height |
