07-23-2003, 06:10 PM | #1 |
Wheelbase
Today I looked at a frame for a 1968 C-10 and the wheelbase measured approximately 133". I believe I read somewhere the shortbox was 115" and the longbed is 133". Can someone direct me to the right answer.
Thank you |
07-24-2003, 08:53 AM | #2 |
Fabricate till you "puke"
Shortbed was 115", longbed 127", & the Longhorn was a 133" wheelbase. The longhorn was an 8 1/2' box,& available in 20 & 30 series only, & will have leaf springs on the rear. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-24-2003, 08:57 AM | #3 |
Whelbase
Thank you for the reply.......This frame is 133 and has the springs near the rear.
08-02-2003, 05:53 PM | #4 |
133" Wheelbase
I still have questions about this long wheel base frame. I bought it to shorten it to the 115" wheelbase to fit my shortbed.
I can't find much info on this wheelbase configuration, only that it may have been a "Longhorn". I would feel silly to cut this frame down to the 115" and find out that it is a somewhat rare frame and should be preserved. Any suggestions or history is appreciated. Thank you, Merl |
08-02-2003, 07:38 PM | #5 |
Designated A-hole!
Post this on the 67-72 Message Board and you will get more response. I am sure that our resident Longhorn "fanatic and guru" Longhornmail can tell you what you need to know about it!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-02-2003, 08:59 PM | #6 |
The longhorn used the same chassis that would be found under a 30 series (133 wb) dump truck. The dump truck had dual wheels, & an extra stack of leafs.....otherwise, the spring lenght,& width spacing should be the same. crazyL
