Pulling an sm465
Can someone give me a detailed step by step on how to pull an sm465/205 out of a k10? Thanks!
Re: Pulling an sm465
Probably missing a few things,but here goes: First thing is get hold of a good transmission/transfer case jack.I bought a cheaper one probably close to twenty years ago & it still works good,had a threaded rod instead of a hydraulic cylinder.Drain your T case,disconnect driveshaft,speedo,shift linkage on t case.Support the transmission/transfer case(some might not agree,but this always works for me) by using a square piece of metal or plywood approx 6" square under the oilpan & a bottle jack under it.Using the tranny jack,place under the t case & unbolt it from adapter.Make sure it's supported well. When I was a lot younger I bench pressed the 205 out,but I got wiser as I grew older! Once t case is out.Remove the crossmember,place jack under tranny,remove the trim around gear shift lever & remove the stick.Push down on the retainer & turn 90 degrees. Usually I unbolt the 4 1/2" bolts on tranny to bell housing & pull it that way,after it's out,then drop your engine down some & undo the bell housing to engine bolts if you need to take that much apart.If your going to leave it any length of time,support the engine better & don't rely only on the bottle jack. Oh,forgot too,you have to drop the front driveshaft from t case as well.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Wish I would of seen this ahead of time lol, guess I need to follow these steps instead of trying to remove the T-case & transmission as 1 big part.
RoughKuntry 73 GMC 25 HUNDRED :Sold 79 GMC High Sierra 4x4 (Ma-Duece) :Sold 99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling 88 Chevrolet Burban 2500 4x4 :Buying ![]() |
I've always done it that way,easier to try and support on a floor or tranny jack too. I wonder how the op made out? Never heard a reply back????
i have done it both ways if you are alone spite the case and trans. only thing i say diff then what was said is i used a jack stand under the motor and some 2x4 behind the heads to keep it from ripping the rubbers
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
