Old 06-06-2014, 07:44 PM   #1
1972BlueC20
1972BlueC20's Avatar
throttle cable issue
Is it possible to have a situation where the throttle cable is either adjusted wrong or bad and needs replacing?
My truck is running great, but it seems like it should be much stronger when I floor it. It just doesn't get up and go like a 350 should.
If it can be adjusted please let me know how!
Or if anyone has any other ideas as to why it wouldn't have the power it should.
The timing is correct, the truck has a brand new carb and all new ignition parts....it doesn't miss at all....runs really smooth
Thanks in advance!!
1972 C20 LWB, 350 engine with TH350 trans
1972BlueC20 is offline   Reply With Quote
Old 06-06-2014, 08:53 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: throttle cable issue
Check and see if the cable is binding, make sure you are getting wide open throttle. You may have the wrong size cable, the stock cable is not adjustable. If all else is well and it just feels like there is no power do a compression check.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-07-2014, 12:17 AM   #3
oldschool18
oldschool18's Avatar
Have someone press down on the petal with the motor off.......with the petal the whole way to the floor the throttle should be wide open. Or atleast that's how I was taught and how I always have done it.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 06-07-2014, 06:31 AM   #4
dirtyjim
dirtyjim's Avatar
you can slightly oblong the holes in the throttle cable bracket that's bolted to the back of the carb to move it back slightly if your not getting WOT.
also the edeljunk carb will not make the same sound when the secondary's open as the quadrajunk carb that you originally had, to some people this makes then feel like it has less power.
if you need any help on it just let me know, jr
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 06-07-2014, 12:39 PM   #5
FirstOwner69
FirstOwner69's Avatar
I'm not a mechanic, but you say the lack of power is when you floor it. Does the transmission downshift when you do this? If not you may have a problem with the kickdown mechanism.
FirstOwner69 is offline   Reply With Quote
Old 06-07-2014, 11:41 PM   #6
1972BlueC20
Thanks everyone!
I figured it out.
It was the little cable that attaches to the gas pedal arm below the dash. The cable has a little cable lock nut thing. It had way too much slack. The pedal was almost all the way to the floor in the default position. I took the slack out of the cable and cut the other cable nut off and put another adjustable nut on. Problem solved. This thing feels like a whole new truck now. It hauls ass!
I also thought I was having a problem with my kickdown cable because it wasn't kicking down into gear. Well it was just because I wasn't getting WOT. Truck is running great now. Burns the tires!!!!
Thanks for all the help!!
