Old 07-08-2014, 04:04 PM   #1
DWilbur
1971 K20 LS 5.3L Swap issue headers
I have installed my LS 5.3 L in to 1971 K20 4X4 truck and I'm having issue with the headers fitting Dough Throly THY 323. I talked to Dough Thorly tech prior to buying the headers to confirm that they will fit my application. they confirmed they fit. Well they don't even come close. I would like to use headers, does any one know what headers will fit. I have a Dirty Dingo motor mount installed. with 1987 bell housing with hydraulic clutch.
DWilbur is offline   Reply With Quote
Old 07-09-2014, 12:27 AM   #2
71chevystep4x4
71chevystep4x4's Avatar
Re: 1971 K20 LS 5.3L Swap issue headers
Hooker block hugger shorties #2312
71chevystep4x4 is offline   Reply With Quote
Old 07-09-2014, 12:44 PM   #3
DWilbur
Thanks for the info. would you by chance have pictures of them installed.
Old 07-09-2014, 12:53 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The frame areas look minimal, I'd just clearance out the problem area. I'm not running a manual, but some "massaging" of the mounting ears on the auto's isn't uncommon.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-09-2014, 02:05 PM   #5
DWilbur
I would have to cut out the hole top flange of the frame for the right and left side. The left side the collector runs right into the hydraulic clutch bracket on the side of the bell housing.
Old 07-12-2014, 11:52 PM   #6
67Steven
67Steven's Avatar
I am running DT headers and I did need to clearance the frame, just a small scallop on each side, but I reinforced the inside area, no problems so far.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744
67Steven is offline   Reply With Quote
Old 07-17-2014, 07:13 PM   #7
DWilbur
I checked out your build thread a couple of time it looks like your engine sits about 1 higher than mine. so the DT headers fit better. your using an auto transmission. I still have problems with the hydraulic clutch bracket that is molded in to the bell housing I would like to use.
Old 08-23-2014, 07:09 PM   #8
DWilbur
After trying 3 set of headers finally the Headman block huger headers will fit only trimming 1.4" out of the top rail of the frame on each side.
Old 06-07-2016, 05:35 PM   #9
preciador6
So it dont matter if i buy DD or Pac fAb im still going to have trouble with headers?
preciador6 is offline   Reply With Quote
Old 06-07-2016, 11:02 PM   #10
DWilbur
That's what i found out. I ended up using the Dough Thorley headders and had to modify the 2 front tubes to clear the frame.
