Old 07-18-2014, 06:05 AM   #1
Paul Y
What rear axle ratio's are you running
Good morning Gentlemen,
As my build is now approaching the physical rather than the esoteric, my shopping list for upgrades is becoming more defined.
So, today's series of question:-
What axle ratio are you running and what is the rest of the drive line?
Mileage?
Are you happy with your choice?
Eventually I will run a LM7, TKO 600 (road/race gearing) and a 265/65/15 tyre/tire.
My initial thoughts were to copy the Tahoe gearing (3.42-3.73- 4.11) but get conflicting reports and, as I wont be towing a 3000lb ski boat, a lot of it is irrelevant.
I will be using the truck as a DD but also for track days/autocross events.
Previous experience with a DNE 4+1 saw me use a 3.25 with 29" tyres. With a BBC I got over 18mpg and ran a very low 12second quarter.
Look forward to hearing your thoughts and comments.
P.
Paul Y is offline   Reply With Quote
Old 07-18-2014, 07:57 AM   #2
Clyde65
Clyde65's Avatar
Re: What rear axle ratio's are you running
I run a 3.73 in my 12 bolt 71/72 rearend. I have a 4.8/4l60E. with this ratio, I feel it hits the sweet spot with the OD trans and also quick starts off the line when needed. I also use a 29" tire ( 275/60/15BFG)
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-18-2014, 08:18 AM   #3
Paul Y
Thanks for the reponse
What sort of mileage are you achieving?
P.
Old 07-18-2014, 09:47 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
I'm running 3.73 in my stock 12 bolt truck axle....30 inch tire...Feels like I need and OD trans at 65...but cruising at 55 at 2500 rpm gets me around..oh...15 mpg...my 292 is old an worn out..so once I rebuild it I'll be able to figure the mileage a little better.
Old 07-18-2014, 10:26 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
3.70 behind a 4L80E transmission and 31" tall tire.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-18-2014, 11:42 AM   #6
Clyde65
Clyde65's Avatar
P.
I have gotten 19.5 on mostly highway ( 75/25) I think if there wasnt much wind ( yeah right) I could get 20.5 on all highway.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-18-2014, 11:16 AM   #7
NEWFISHER
NEWFISHER's Avatar
""" My initial thoughts were to copy the Tahoe gearing (3.42-3.73- 4.11) but get conflicting reports and, as I wont be towing a 3000lb ski boat, a lot of it is irrelevant.""?"
If never towing and using as DD I would run the 3:42
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 07-18-2014, 11:35 AM   #8
Shaky
Six in a row makes it go...
Shaky's Avatar
250/Richmond 5-speed/3.08
You can only expect so much mileage as you push a brick through the air...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-18-2014, 07:43 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have a 3.08 and 28" tall tire. I wish I had more gear.. I run 70 @ 2600 rpm.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-18-2014, 08:05 PM   #10
The original rear with 3.73 gears and 29" (275'60x15) tire. I have no clue what I get for mileage as I have not gotten the speedometer gear in the tranny replaced yet. It does wind at 65/70 on the road, but it does it well.I plan on going to a 3.08. I am running a 3 speed manual tranny. Best guess is around 13-15.
Old 07-18-2014, 10:22 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
In my truck at present is a 3.90 with 26" tire.
it revs way too high at only 50mph.
I'm going to swap it to a 3.08 this winter.
If it bogs it down too much, I'll put the 3.73 I also have.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-19-2014, 04:11 AM   #12
Paul Y
Wow,
A lot of information! I have used an online gear calculator that shows with the .84 5th gear and a 3.73 gear 70 comes up around 2500, with a 3.42 the same rpm gives me 76mph.
I suppose my real question is where is the sweet spot for the LM7? Think I will try one of the LSx forums unless anyone knows better?
Thanks for the input.
P.
