What rear axle ratio's are you running
Good morning Gentlemen,
As my build is now approaching the physical rather than the esoteric, my shopping list for upgrades is becoming more defined. So, today's series of question:- What axle ratio are you running and what is the rest of the drive line? Mileage? Are you happy with your choice? Eventually I will run a LM7, TKO 600 (road/race gearing) and a 265/65/15 tyre/tire. My initial thoughts were to copy the Tahoe gearing (3.42-3.73- 4.11) but get conflicting reports and, as I wont be towing a 3000lb ski boat, a lot of it is irrelevant. I will be using the truck as a DD but also for track days/autocross events. Previous experience with a DNE 4+1 saw me use a 3.25 with 29" tyres. With a BBC I got over 18mpg and ran a very low 12second quarter. Look forward to hearing your thoughts and comments. P. ![]() |
![]() Join Date: Aug 2004
Re: What rear axle ratio's are you running
I run a 3.73 in my 12 bolt 71/72 rearend. I have a 4.8/4l60E. with this ratio, I feel it hits the sweet spot with the OD trans and also quick starts off the line when needed. I also use a 29" tire ( 275/60/15BFG)
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks for the reponse
What sort of mileage are you achieving? P. |
![]() Join Date: Mar 2013
I'm running 3.73 in my stock 12 bolt truck axle....30 inch tire...Feels like I need and OD trans at 65...but cruising at 55 at 2500 rpm gets me around..oh...15 mpg...my 292 is old an worn out..so once I rebuild it I'll be able to figure the mileage a little better.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
It's Better With Nitro
3.70 behind a 4L80E transmission and 31" tall tire.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
""" My initial thoughts were to copy the Tahoe gearing (3.42-3.73- 4.11) but get conflicting reports and, as I wont be towing a 3000lb ski boat, a lot of it is irrelevant.""?"
If never towing and using as DD I would run the 3:42
GOD BLESS AMERICA! |
Six in a row makes it go...
![]() Join Date: Mar 2009
250/Richmond 5-speed/3.08
You can only expect so much mileage as you push a brick through the air...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
I have gotten 19.5 on mostly highway ( 75/25) I think if there wasnt much wind ( yeah right) I could get 20.5 on all highway.
Who Me?
I have a 3.08 and 28" tall tire. I wish I had more gear.. I run 70 @ 2600 rpm.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
![]() ![]() Join Date: Jul 2002
The original rear with 3.73 gears and 29" (275'60x15) tire. I have no clue what I get for mileage as I have not gotten the speedometer gear in the tranny replaced yet. It does wind at 65/70 on the road, but it does it well.I plan on going to a 3.08. I am running a 3 speed manual tranny. Best guess is around 13-15.
But Found Her 25yrs Later!
In my truck at present is a 3.90 with 26" tire.
it revs way too high at only 50mph. I'm going to swap it to a 3.08 this winter. If it bogs it down too much, I'll put the 3.73 I also have.
Wow,
A lot of information! I have used an online gear calculator that shows with the .84 5th gear and a 3.73 gear 70 comes up around 2500, with a 3.42 the same rpm gives me 76mph. I suppose my real question is where is the sweet spot for the LM7? Think I will try one of the LSx forums unless anyone knows better? Thanks for the input. P. ![]() |
