Old 07-20-2014, 03:07 PM   #1
hotrod66
hotrod66's Avatar
one piece at a time
i am starting this a little late i have ben working since april so i will try and catch everyone up. i first built back in 09, to protest to my whiney neighbor who constantly complained about my old cars sitting in my yard. He called the county which told me i needed to put a fince up around my 3 old cars so i did. then drug the ugliest truck i had out and made it live just building it out of junk that i had. in a strange series of events this became my daily driver so what started out as a joke ended up saving me, life is funny that way. fast forward to 2012 i t boned a van that ran a stop light and bent the frame the truck was deemed totaled but i fixed the best i could with a torch and keep-et on trucking.
then in march of 2014 the 250 that had pulled the truck for 4 years that was junk when it was put in finally died. knowing the frame was bent the truck was disassembled and put on a short frame and a 292 was sourced from my favorite small town junkyard and overhauled. keeping with the original intentions i am building the truck mostly form my parts pile and junkyard parts with few new parts such as a/c (finally!) oh yea and carpet. my goal with this truck is to make the people who get it smile and for the ones who dont can just look down there noses at me in disgust get in there prius and go home to there Mickey mouse world! ps that whiney neighbor finally moved!
as of march last shot before tear down
tear down
new frame
rebuilt 292
resealed the trans it worked fine so just cleaned it up
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 07-20-2014, 06:56 PM   #2
RANDY COX
RANDY COX's Avatar
Re: one pice at a time
Hey that 292 looks familiar....
Yours is lookin Great...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 07-20-2014, 08:55 PM   #3
hotrod66
hotrod66's Avatar
it sure does! i have had fun trying to fine all the mounts for my 292 as it was in a 78 1 ton.i didn't realize the mount was different on the block as well as the stool.i found both stool and block mount and spacers today along with a set of used brass knuckles in the bed of the same truck covered up, the junkyard i go to is kinda shady you never know that you will find.
Old 07-21-2014, 07:39 PM   #4
hotrod66
hotrod66's Avatar
fixed a hole in the roof the previous owner had a cb antenna stuck in. next patch is the cab corner, i dont know how i didn't notice this when i put the rockers on but the cab corner had ben mashed in and built back up with bondo it wasn't rusted just flattened.
Old 07-21-2014, 07:40 PM   #5
hotrod66
hotrod66's Avatar
hope to get my fly wheel back tomorrow from the machine shop so i can get my engine in finally
Old 07-22-2014, 09:41 PM   #6
hotrod66
hotrod66's Avatar
a update for today got my flywheel back and clutch installed along with trans.
and oh yea i got the whole mess put in the truck finally!!!
i used a old input shaft to line up the clutch and also put in the pilot bushing. the input shaft is from one of my old saginaw 3 speeds. this is why you dont side step a clutch when your mad at some one and you have 3:08 gears. learned a lesson on that one twice because it also broke the drive shaft.
my truck is to low to get my cherry picker under it. cant use jack stands due to the width of the cherry picker, so i used some old wheels to get it up in the air.
Old 07-22-2014, 11:50 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
292 I6 is a sweeeeeet engine...proof here....ahem...this one is mine. lol
https://www.youtube.com/watch?v=YoiM...fzpcUXyK_5-uiw
Old 08-19-2014, 09:14 PM   #8
Bomp
Bomp's Avatar
Re: one piece at a time
Really dig the color on the motor and the 4 door model.
Ill follow along on this cool build.
Bomp is offline   Reply With Quote
Old 08-19-2014, 10:01 PM   #9
hotrod66
hotrod66's Avatar
thanks its alpine green close to a factory color for the 292 engine. the model well i get bored and build things, think i might make it a dually as well.
Old 08-19-2014, 11:16 PM   #10
pimpston65
pimpston65's Avatar
whats up with that burban??? future build???
pimpston65 is offline   Reply With Quote
Old 08-20-2014, 07:57 PM   #11
hotrod66
hotrod66's Avatar
one that stalled out, due to daily driver issues. im to stubborn to by a late model car so i rebuilt a 88 silverado and drove my 66. the 66 then gave it up as soon as i finished the 88. so yes its next in line. i have already done a few patches in the floor and rebuilt the front end, disk brakes. i have a rebuilt 350hp 327(used a repop 350 hp cam they used in the vett and a old set of double hump heads)and a 700r4. i have 90% of the parts for it just need to get on it after my 6 banger truck.
Old 08-20-2014, 09:18 PM   #12
hotrod66
hotrod66's Avatar
hung the door today. need to start body work and fill the 14 holes form all the different mirrors. glad to have a set of doors with out speaker holes in them.
Old 08-24-2014, 05:09 PM   #13
hotrod66
hotrod66's Avatar
Welded my holes in the door,pulled the dints the best that i could and slung some short strand fiberglass. I still need to do some more work to it so i just hit it with some rattle can filler primer to keep the flash rust away. I got a new finder from work got, it home and immediately dropped it in the floor and dented it.
I bought some slick sand filler primer going to see if i cam make my truck look like a mountain range from all the runs. Last but not least I got a new hauler. the truck is a c-20 with a granny 4 sm420, 292. guy at the junk yard said it ran when he got it a month ago, gas was fresh in the tank. As fate would have it thats where my carb and motor mount stool came from for my truck i am building .
if any one has a spare passenger side stool for a 292 i am in dire need of one.
Old 09-06-2014, 09:07 PM   #14
hotrod66
hotrod66's Avatar
Not any big progress but I got my 3/4 ton home and running. On the project truck I decided to just use my old passenger door that was on the truck. the other door I was working on was tweaked bad at the top due to it was off a wrecked truck, I had it almost done and set on the truck and it was then I realized it. I fixed a 6x9 hole that was cut in my old door started to freshen up the body work on the out side. I finished the drives door body work. sand blasted the driver side inner finder and shot under side with undercoating. i am going to do the top side of the inner finder in spray can truck-bed liner (i have used it in the past and does not look like what you would think it turns out almost completely smooth and is chemical resistant). still on the hunt for a passenger engine mount stand for my 292 if anyone has one.
Old 09-25-2014, 09:09 PM   #15
JWheeler331
JWheeler331's Avatar
Nice progress
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
Old 09-25-2014, 11:40 PM   #16
collins10672
collins10672's Avatar
cab corner looks nice.i really like your build.
collins10672 is offline   Reply With Quote
Old 09-26-2014, 12:16 AM   #17
Captainfab
60-66 Nut
Your build is looking good.....I agree on nice job on the cab corner.
Old 09-26-2014, 06:16 PM   #18
hotrod66
hotrod66's Avatar
thanks guys! i try to do at least one thing a day to it ,no matter how small it my be it is still progress.
Old 09-26-2014, 09:29 PM   #19
hotrod66
hotrod66's Avatar
well i got my mustang tank in today. i had to cut allot more than i really wanted to on the frame. i didn't think it was going to take that much to fit it in there. all well its to late now im committed to it , think i may box that area in the back. tomorrow im going to change my track bar mount on the frame from the 65-66 mount to the 63-64 so i can use the adjustable track bar i bought.
Old 09-27-2014, 09:36 PM   #20
hotrod66
hotrod66's Avatar
cut my track bar rivets out on the frame and ready for the new 63-64 one.
welded the rear cross member in also did what im going to call a mini box on one side. that way i can still reach the top side of the inside of the rail so i can bolt in my mustang tank. will finish the other side tomorrow
Old 11-17-2014, 09:10 PM   #21
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Nice work! What are you using to strip the paint?
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 11-17-2014, 09:36 PM   #22
duallyjams
duallyjams's Avatar
looking good
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-17-2014, 09:38 PM   #23
hotrod66
hotrod66's Avatar
Originally Posted by duallyjams View Post
looking good
thank ya!
Old 11-17-2014, 09:38 PM   #24
hotrod66
hotrod66's Avatar
paint/rust striper wheels got 10 of them off ebay for $25 they work well. 3m also makes some you can normally get the wall-mart for $10 each.
Old 11-17-2014, 10:16 PM   #25
Mikes66ChevyC10
Attachment 1325969
Attachment 1325973
Excellent! Thanks!
