08-21-2014, 10:30 PM | #1 |
Parking brake cable routing
Anyone got a picture of the parking brake cable routing? My Sub is missing the equalizer rod that on the passenger side. What does it connect to? This is the rod that is on the opposite side of the front cable adjuster rod.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
08-22-2014, 08:23 AM | #2 |
This photo may help if you can zoom in (this is 4 x4 may not be the same as 2 WD ) ?
08-25-2014, 01:37 AM | #3 |
Found a better photo.
08-25-2014, 01:44 AM | #4 |
What?
Re: Parking brake cable routing
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-25-2014, 07:03 AM | #5 |
Thanks guys!
Using photoshop I lightened up your first picture and can see that the rod hooks through a hole in the frame on the right hand side. Once the LMC parts come in it shouldn't be tough to figure out which hole. Paul
08-25-2014, 01:46 PM | #6 |
This should help. Tape "0" datum is the front of the frame rail. First hook hole (long one ) is at 77 1/2 " . Next one is at 96" . Again ,this is a 4 x 4 but I see no reason that it would be different on 2 WD. Hope this helps.
08-25-2014, 05:16 PM | #7 |
Awesome. Now that helps!
Thanks! Paul
09-01-2014, 07:28 PM | #8 |
I can say for certain that the rear cables listed in the LMC catalog are correct for a 4WD. They match the originals perfectly.
Something weird in your picture Franks 72 your cable guides are bolted to the inside TOP of the frame rail. On my 70 they were bolted in bottom channel. Paul
09-02-2014, 12:12 AM | #9 |
Cant explain the difference. This was a Canadian truck?
My second hook is not bolted just hooks on the frame rail the same as the front. Perhaps they changed something in the 72 4X4 ? |
09-02-2014, 04:28 PM | #10 |
my 72 K20 pigtails were located on the top of the frame rail and were not bolted. The hook on the end of the pigtail just went through the hole and was held in place with the tension of the cable.
09-07-2014, 07:09 PM | #11 |
Took a chance on the LMC cables and they were a perfect match to what was on the truck. Now the problem is that the ones I took off might have been wrong! I found the holes to mount the rear cable brackets on the top of the frame rail. My brackets were mounted on the bottom of the frame rail a few inches back. To clear the frame bracket rivets, the brackets had 1/2" long spacers. The new (and old) brake cables are too short to allow mounting on the top of the frame in the original holes.
The top photo is one of Lock Doc's from 2011 and the bottom is from my truck. Paul
09-07-2014, 08:10 PM | #12 |
I'd say, someone rigged yours in the past
09-07-2014, 10:38 PM | #13 |
Yep. That was my guess too. Only thing is, it was rigged before I bought it in the early 80's or I don't remember rigging it!
Paul
04-10-2015, 10:58 PM | #14 |
This thread has been extremely helpful, I was wondering if anyone had pictures of how the front cable is routed and secured on a 4WD. I have a 72 K10 and the previous owner had rigged it with a 2 wheel drive front cable that was not secured and they fabricated a bracket to hold it under the truck. I got new cables from Inline Tube and would like to get it install correctly.
Thanks |
04-23-2015, 06:13 PM | #15 |
I would also like to see a few more pictures of how you all have your e brake cables routed and/or attached please.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
04-23-2015, 09:33 PM | #16 |
I have to agree with Bob and I too would like to see more pictrues.
Posted via Mobile Device |
05-27-2016, 08:33 AM | #17 |
Our truck is a 1970 K/10 longbed as it sits right now. When we bought it, prev owner has cable from inside cab coiled up on LF fender. Has cables from brakes dead ended-just kinda hanging there.
I'm looking at LMC and ordering "Intercable Longed 4WD", "Park Brake Cable Guide Kit", and a "Park Brake Cable Grommet". Anything else I need? This thread is most helpful as I am not sure exactly the routing needed. Anyone have more words of wisdom or more pictures for a newbie? Thanks! |
09-22-2024, 01:43 PM | #18 |
Helpful
