72 Chev Tremec w/ZZ 454
Here are some pics I thought you may find helpful if your installing a Tremec TKO600 or ZZ454 into a 72 chev
Re: 72 Chev Tremec w/ZZ 454
Some additional pics.
More pics.
I also needed to change the clutch disk from a 10 spline to a 26. |
Floor patch
Okay so I had to:
-Cut the floor (although you may be able to slip it in without doing this. I did it to make things easier) -Shorten the driveshaft (I had a 1330 yoke put on the driveshaft to match the 1330 slip yoke that goes in the transmission) I am still running a 2 piece driveshaft -Drill new cross member mounting holes to support the tailshaft -Clean off the paint on the bearing retainer hole for the scattershield so it would slide in properly -Buy Ford plastic speedo drive gears to match my rear end ratio and tire size -I also purchased the shifter, shifter knob, reverse light harness, and speedo drive adapter from American Powertrain Other than that I would highly recommend the 5 speed. It works great and now I have the best of both worlds. Get up and go as well as hi-way driveability! |
