10-16-2014, 07:02 PM | #1 |
air ride for blazer
thinking about bagging my 80 blazer....the rear is a flip kit now...that has to be taken out for air ride?...is a 4 link set up the best alternative?
this is a daily driver so want to figure out the best value. |
10-19-2014, 01:45 PM | #2 |
Re: air ride for blazer
Not many people post on here but I'm in the same boat. It appears that a parallel 4 llink isthe best way to ggo because u get the most travel with the least amount t of floor alteration. If someone knows better feel free to chime In
10-20-2014, 12:30 AM | #3 |
depends on what you are planning on doing..
parallel 4 link is ok but the question is how are you going to keep the side to side from moving? If you are going to use a panhard bar then you will need a long bar to eliminate side to side motion of the axle. If you have a short bar and lots of travel then you will get a lot of movement in the axle. Now if you are going to do a watts link you get no side to side movement and you can get a decent amount of lift as well.. The other option is a triangulated 4 link. With the triangulated link the angled bars eliminate the side to side movement of the axle just link a watts link does but with only 4 bars. What ever you do make sure the bars go forward and work with whatever you have. Also between a 4 link versus the leafs. I always suggest using bars because you won't have issues with your pinion. |
12-12-2014, 12:08 PM | #4 |
Everybody has their own opinion as to which one is best, just have weigh out your options. A 2-link is very cheap and gets you plenty of lift. , but either a watts link or a panhard hard is needed. A 4-link is slightly better, but you have to go bag over axle which doesn't give you very much lift and a panhard bar or watts link is still recommended. Then there's triangulated 4-link which eliminates the panhard bar or watts link. Those are just the basic systems. This OP is for a Blazer, so you need to also keep in mind how much of the bed you want to cut...back seat issues, etc.
01-02-2015, 06:52 PM | #5 |
I say do an AOL setup and keep the stock floor
You won't lay frame but you can get it pretty low.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
