11-23-2014, 01:11 PM | #1 |
LS swap radiator options?
Swapping an LQ4 6.0 into my c10 what's the best radiator/ place to deal with for my swap? Any help is appreciated.the old radiator is useable but slightly funky I'd rather invest in a better one with electric fans but not sure who to deal with/ the right configuration.looking for advice-Jeff
11-23-2014, 01:57 PM | #2 |
Re: LS swap radiator options?
I got a Griffin ls swap radiator for mine, I'm doing a 4.8l in my 76, its a nice radiator. I am having a little trouble mounting it though, I don't have the original radiator retainers and I am having to make some up. I know there is a vendor here on the board that sells radiators for this swap as well.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
11-23-2014, 04:13 PM | #3 |
Cool I'll check m outgotta find a few and see what's the best fit for my situation I don't want cooling problems don't want to spend a bunch of money and get the wrong fit that's why I figured I'd ask here first beforehand
11-23-2014, 04:45 PM | #4 |
Hi.
Im also puting an LQ4 in my truck now I went with Griffin. I only test fitted it so far, but measurements and fit looks ok.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
11-23-2014, 07:56 PM | #5 |
Griffin hmmm sent them an e mail to see what they might be able to come up with seen a few rigs using their components might be the way to go trying to weigh my options thanx for the input
11-23-2014, 08:20 PM | #6 |
Cruzzzn' Vet
11-24-2014, 10:27 AM | #7 |
Slots go on anything!
I used a new stock radiator and clutch fan. Mostly because I am cheap.
1974 Jimmy- 5.3/4L80e/NP241 |
11-24-2014, 01:50 PM | #8 |
Diggin The SquareLife
http://www.summitracing.com/search/m...-based-engines
if I was doing an ls swap I would use one of these and stock ls1 fans |
11-24-2014, 06:00 PM | #9 | |
11-26-2014, 06:47 AM | #10 |
After much contemplation and research I'm gonna take bbbc10s and others (Matt/Tom thanx for weighing in.)advice and go with the griffin radiator I'm highly allergic to buying things twice so I appreciate the input I don't want any overheating problems my stock radiator is still good but is kinda funky not gonna chance it
12-04-2014, 11:01 PM | #11 |
You'll be much happier with a stock radiator, if you use a 2010 Camaro water pump. The waterneck is on the driver's side. It requires a minor relocation of the idler pulley. Dirty Dingo has a $26 kit to do that.
I used the 2010 Camaro pump, '05-'08 top hose, LQ4 lower hose, and H1 8.1L belt. My radiator is the OE 454 HD cooling option, with matching cushions and top plate from LMC. It's strapped down by a fan shroud I designed. Twin fans are from a LT1/LT4 Camaro. Radiator was $140; Fans were pick-n-pull $20!!!; Top mount was about $40 with 4 cushions; Waterpump was $160, loaded with tensioner, pulley, thermostat and housing; Idler relocation bracket was $26; Top hose was $8; lower hose was $12; Belt was $35. |
12-05-2014, 06:04 AM | #12 |
Wow,looks pretty clean nice work
12-06-2014, 07:58 AM | #13 |
12-08-2014, 02:30 PM | #14 |
Did your PRC radiator outlet fit your LS waterpump outlet?
12-08-2014, 06:41 AM | #15 |
Cool$$$$$
12-08-2014, 08:51 PM | #16 |
it did so
12-09-2014, 10:08 AM | #17 |
They must have measured twice for yours !
