Old 11-25-2014, 12:31 PM   #1
Eraser475
Eraser475's Avatar
Interior cleaning products?
I wanna clean up my dash and door panels, but I have heard that Armor All leaves a film that prevents it from future painting of them. Is there anything to clean them with that doesn't do this?
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 11-25-2014, 01:01 PM   #2
85chevy86
Re: Interior cleaning products?
I am not 100% but aerospace 303 might be good if you plan on painting them later. It does not have any silicone in it. I think.
85chevy86 is offline   Reply With Quote
Old 11-25-2014, 01:49 PM   #3
bnoon
To clean them, I use the hottest water I can get, no soap, and a wash rag. If it requires more than that, I use Goop hand cleaner (without pumice).
For protectant, I use Auto Armor (no silicone).
You can always prep for paint/dye, even if you've used Armor All before. You will prep for paint/dye if you're doing it right anyway and odds are that Armor All was used at least a few times back in the 80's-90's on your truck even if you don't.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-25-2014, 03:08 PM   #4
Eraser475
Eraser475's Avatar
How does one fo about removing the silicone film from the interior if it has been used before? And basically any auto cleaner without silicone is good?
Old 11-25-2014, 03:57 PM   #5
homemade87
The stuff they use before paint to clean the surface ( some call it prepsal ) is supposed to remove silicone pryer to painting .
homemade87 is offline   Reply With Quote
Old 11-25-2014, 04:21 PM   #6
JWall
Frequent Flyer
JWall's Avatar
There are some alternatives to armor all that are supposed to be more "body shop friendly" or easier to remove for painting purposes like Wizards... http://www.wizardsproducts.com/tire-vinyl-shine-22-oz/
I use TSP to clean door panels, trim pieces, etc before painting & have had good luck.
http://www.lowes.com/pd_208321-91-10...7C1&facetInfo=
- Justin
1 Owner 1976 SWB
Old 11-25-2014, 04:49 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
I use "spray nine" cuts coffee and grease very good.
rubbed with a soft bristle brush
rinse with hot water
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-25-2014, 08:49 PM   #8
tucsonjwt
Not sure about cleaning - I use general purpose cleaner from Dollar Tree for $1 per bottle, and their $1 carpet and upholstery cleaner. x2 on 303 - I use it on all of my tires - very pricey but you can use it sparingly and it lasts a long time - leaves no shiny appearance - works well even in the desert heat.
tucsonjwt is offline   Reply With Quote
Old 11-25-2014, 09:21 PM   #9
MalibuSSwagon
I use Purple Power for most of my general cleaning needs, diluted in the right amounts I use for everything from cleaning interior surfaces, carpet shampooing to degreasing engines. Works great.
MalibuSSwagon is offline   Reply With Quote
Old 11-25-2014, 09:44 PM   #10
bnoon
To remove Armor All... Mineral Spirits (you can get stink free for more $) or Kleen Strip's wipe down prep is actually called Prep-All. Everybody always says Preps-all but there's no S in there. Bugs me. LOL! Both are safe for plastic.
FYI, Purple Power, Simple Green, etc. can leave a film just because they are such strong degreasers, it's the nature of the product. Good for heavy cleaning, bad for paint prep.
Old 11-25-2014, 09:52 PM   #11
3drburb
Tuff stuff (yellow and red can) will do the job, along with a clean white clothe and warm water.
3drburb is offline   Reply With Quote
Old 11-25-2014, 11:28 PM   #12
MalibuSSwagon
Usually I use PP for general cleaning, not paint prep. With vinyl I use laquer thinner to wipe down before any prep work begins, then prep-all before refinishing.
Old 11-26-2014, 12:24 AM   #13
allchevy58
allchevy58's Avatar
Simple Green and warm water works for me.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-12-2014, 02:33 PM   #14
BigMike608
BigMike608's Avatar
this is cleaning process I used when I cleaned and freshened up my interior a few years ago...
First I mixed in Clorox with a large bucket of very soapy water and used a scuff pad to clean every inch of each piece and then rinsed thoroughly. I repeated this process 4 times for each piece. Next I dried off each piece with a lint free microfiber towel. Then I thoroughly cleaned all pieces once again using automotive grade lacquer thinner making sure to only wipe in one direction to keep from spreading the leftover residue. After all this was complete, I let everything sit and dry for 24 hours. Once it was ready for paint I did 2 light coats of Bulldog adhesion promoter with 5 mins between coats. Finally I used the SEM color coats and sprayed 6 lights coats on each piece with 5 mins flash/dry time between coats. I let everything set for a few days to make sure it was completely dry before I begin re-installing.
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 12-13-2014, 03:29 PM   #15
lilpoindexter
lilpoindexter's Avatar
Vinylex bro.
http://www.walmart.com/ip/16529117?w...962143&veh=sem
lilpoindexter is offline   Reply With Quote
