Slots go on anything!
2014-up drop kits?
Has anybody had any luck with a drop for a 2014- up Silverado? Looking for recommendations for either 2/4 or 3/5.
Thanks, Jon
1974 Jimmy- 5.3/4L80e/NP241 |
GM Addicted
Re: 2014-up drop kits?
4 inch or greater rear drop will require a flip kit and shackle bracket. Different combinations depending on company's. A simple quick drop I do for customers is a 2 inch spindle up front and 2 inch shackle in the rear as well as removing 1 inch factory block. 2/3 drop and change rear shocks. Always use Belltech. Here's a picture.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
The Peacemaker
This is my 15' SLE with a McGaughy's 4/7 kit. I didn't use the shock extenders, and it rides really good. It actually has a better ride in the rear with the new shocks. I would recommend McGaughy's especially if you want a spindle as they were the first company with the spindle and I mean, with all the trucks I have had, I have had Belltech, DJM, Groundforce, Eibach, and now McGaughys and I'd have to say that I am most impressed by McGaughy's. DJM is probably the most cumbersome and they have the ****tiest customer service I have ever dealt with but the Caltrax or whatever the drop arms are, they are nice too, just make sure you get the adjustment bracket for the top a arms otherwise you aren't aligning anything.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
You get a new sled, JB? McGaughys has been great on my 09. Spindles and struts for a 4/4. I like some rake.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Parts and more parts
Kind of like what 'Low E' says, my 2011 has a 5/7 drop from McGaughy's and it works really well. I have put over 100,000 miles on the truck since the drop. There should not be that much difference from mine to the 2014 in the suspension area.
Frank |
I've been looking. We do some lift kits here at work, but I would like to get into lowering a few also. It looks like I will probably have to buy a truck and make mine the guinea pig.
#7 | |
I also run factory steel rims in the winter with 245/70/17 tires on them.
Frank |
A day late and $1 short...
I am looking at the McGauphy's 4/6 drop part#34170, has anyone installed this kit? What was the difficulty level? Any additional item needed to make it right?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
The Peacemaker
That is the kit I installed if you scroll up and take a look. I installed some Nitrogen Gas Shock - McGaughys 2050 and the truck rides great, no rubbing whatsoever and only thing I've seen/felt is the bumpstops in the rear if there is a hard bump or I have a good amount of cargo. Great kit!
#10 | |
"I talked to the service manager at my dealer and he said the only pieces that would not retain the factory warranty would be those that I replaced. However, if they deem the drop caused a failure of other parts they may not be covered. For instance, if a u-joint fails and they attribute it to a vibration caused by the drop it wouldn't be covered by the warranty. Fair enough, I guess it's the price of looking awesome! I think I will go with a 3/5 drop initially since the drop is adjustable. One question that does come to mind is that you all mention changing shocks. Everything I've read says the kit comes with front struts and rear shock, do they not work well?" I think I'll keep my questions about drop kits in this thread from now on so I don't clog up your build thread. ![]()
#11 | |
The Peacemaker
From what I can tell it appears they added the struts and shock to the kit recently. No matter, with you guy's input I think this is the kit for me. I'd really like to have a copy of the install instructions, I think I'll contact McGaughy's next week and see if they'll email me a copy.
Should not be that hard. You may want to get some degree plates to adjust your front wheel alignment after you are done. I also put on a set of aftermarket shocks to get a better ride. The factory ones are a little deficient at the lower end of the stroke.
Also you may want to look at your plastic front fender liners and see if they are going to rub. If you cut a 4" X 4" opening in the top, they then can be heated and riveted to the metal liner behind them. It gives you a lot of room.
Frank |
