Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-01-2015, 09:51 PM   #1
redsled87
redsled87's Avatar
Stepside bed inner wheel tubs
Has anyone added fleetside wheeltubs to their step side? Mine sits fairly low. I was going to go the whole way into the frame rail in case I want to go bigger in the future. I'm running a 325/50/15 drag radial on a 10" wheel. I've got about 1-2" of gap to the wheel opening from the tire. I'm looking at running a wider 30-31" tall Hoosier Quick Time Pro tire. Can't hurt to have more tire with a torquey big block! Just wondering if I'll be fine with factory tubs or I need aftermarket ones. This is on an '87 by the way. Thanks
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 01-01-2015, 10:38 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Stepside bed inner wheel tubs
http://67-72chevytrucks.com/vboard/s...d.php?t=611423
Old 01-08-2015, 12:12 AM   #3
kpeztruck
kpeztruck's Avatar
I used the fleetside inner fenders on mine. I cut some width out of mine to clear roll cage, etc. I have had as large as an 30.5x10.5w under mine with it sitting low. Never had an issue with tire clearance.
kpeztruck is offline   Reply With Quote
Old 01-14-2015, 11:05 AM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
I had an '84 stepside that was tubbed using the fleetside inner fenders. The PO that did the work jused the inners as is without modification. The inside of the "tubs" where actually past the frame rail. I did not keep the truck long enought to change that, but if I had, I would have narrowed the tubs to keep the inside flush with the outside of the frame rail.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-14-2015, 01:34 PM   #5
Keith Seymore
Keith Seymore's Avatar
That's how we did the white '85 GM racetruck at the proving grounds (no photos available).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
