Old 01-21-2015, 04:26 PM   #1
J1MMY
Pedalbox Swap
Are all C/K manual pedal boxes the same from '73 - '87?
Trying to broaden my search for parts to do a manual conversion in my '79 C10.
Many thanks.
J1MMY is offline   Reply With Quote
Old 01-21-2015, 07:10 PM   #2
83swb
Re: Pedalbox Swap
Yes and no, They all bolt up the same between 73' and 87' but GM switched to a hydraulic clutch in 85'.
83swb is offline   Reply With Quote
Old 01-22-2015, 12:37 AM   #3
andrewmp6
Re: Pedalbox Swap
Yes they all bolt up but the 2wd and 4x4 turn different ways i believe.
Old 01-22-2015, 02:11 AM   #4
J1MMY
Re: Pedalbox Swap
Useful to know the change from cable to hydraulic operation - will help when choosing a gearbox. Does that mean '88 on will also bolt in but will be hydraulic only?
Can you elaborate on that a little?
And just to be awkward are there any GM car pedal boxes that bolt straight in?
Thanks again.
Old 01-22-2015, 02:19 AM   #5
andrewmp6
Re: Pedalbox Swap
I was wrong and right,The difference between the two boxes is the size of the shaft coming out of the box.This will show you how to tell them apart http://tinyurl.com/ok5l8ss and as far as the car ones i have no idea on those.
Old 01-22-2015, 09:48 AM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Re: Pedalbox Swap
I think he's talking about clutch and brake pedal assemblies. Edit to add, if I'm remembering right, the difference between the Hydroboost brakes vs. vacuum is the attachment point of the brake rod - hydroboost uses the upper spot and vacuum the lower. And there is a different set of pedals for hydraulic clutch trucks.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-22-2015, 09:52 AM   #7
J1MMY
Re: Pedalbox Swap
Sorry, yes I am - terminology difference again
