Old 02-17-2015, 01:27 AM   #1
tblazin2k5
looking for bag brackets
I am looking for a set of upper bag mounts for the front of my 67 suburban. I know this sounds easy but here's the twist, someone had mounts on it before so there are holes drilled in my crossmember already so I'd like to find a set of plates without the outer mounting holes in them so I can drill them myself to line up with the existing holes. Does anyone have an idea of where I could find a set? I'd like to support a vendor on the board if possible.
Thanks in advance.
tblazin2k5 is offline   Reply With Quote
Old 02-17-2015, 02:16 AM   #2
andrewmp6
Re: looking for bag brackets
You could cut your own from plate steel.
Old 02-17-2015, 10:43 AM   #3
tblazin2k5
I was thinking about that but figured on it as more of a last resort. This will be my first airbag install.
Old 02-18-2015, 11:31 PM   #4
tblazin2k5
Still looking for brackets. I wouldn't mind cutting my own if I could find some sort of instructions. I can get the shape cut and the holes drilled fine but I'm not exactly sure where to put the bag mount holes. I'm new to airbag suspension and really don't want to make these more than once.
Old 02-19-2015, 11:12 AM   #5
blazer2007
I built my own and and kinda matched up where center would be if it had the coil in and drilled my holes for the bag,was easy and I,ve no problems .
blazer2007 is offline   Reply With Quote
Old 02-18-2015, 11:39 PM   #6
tinydb84
tinydb84's Avatar
Even if the new holes aren't in the same place you can drill new ones. As long as they are an inch apart or so you should be fine.
David
Instagram: myfabguy
Old 02-18-2015, 11:50 PM   #7
tblazin2k5
My concern is that the new brackets will be very close or overlapped. I had thought about welding the holes shut but I would really hate to try to drill through my weld.
Old 02-19-2015, 01:54 AM   #8
tinydb84
tinydb84's Avatar
My best friend is down in Grover btw. Drilling weld isnt that bad. If they are that close then drill all new holes in your crossmember and plate. No big deal.
David
Instagram: myfabguy
Old 02-19-2015, 11:28 AM   #9
tblazin2k5
That's kinda what I figured it would take but being new to this I get a little nervous.
Old 02-19-2015, 12:58 PM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
tblazin2k5
I sent you a PM.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
