Old 04-19-2015, 08:25 PM   #1
gearheads78
gearheads78's Avatar
Pulling my hair out looking for a lower radiator hose.
Should be a simple task to continue with a project. Need a lower radiator hose for a 68 GMC 3/4. Was a v6 truck now a 87 350. Here is a basic template. The sharp "P" shape bend to clear the frame is the problem. A universal kinks at the bend. I'm even willing to put 2 hoses together but after 45 min in two different parts stores hose walls I am still at a loss. I can't find any section of hose in 1 3/4 that will make that bend.
gearheads78 is offline   Reply With Quote
Old 04-19-2015, 08:40 PM   #2
dirtyjim
dirtyjim's Avatar
Re: Pulling my hair out looking for a lower radiator hose.
autozone has the correct hose, you have to cut about 4" off it. it will look like its going to kink till you get it the right length
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 04-19-2015, 09:13 PM   #3
gearheads78
Any idea the part number. Stayed least 45 min in both autozone and orielly wall of hoses today and nothing even close.
Old 04-19-2015, 09:31 PM   #4
Boog
laying low
Boog's Avatar
I wouldn't expect any parts stores to carry many parts in stock for these old trucks. Most can have it next day however.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-19-2015, 09:06 PM   #5
JJR
JJR's Avatar
It will take a while but I'd take your template to the parts store and try to match it up with one on the "wall of hoses".
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 04-19-2015, 09:23 PM   #6
Fldawg
Fldawg's Avatar
looked thru my receipts and here are 2 gates numbers one is upper and one is lower hose don't know which is which, but i think you have to cut some off like dirtyjim said
#20607 or 20694
Fldawg is offline   Reply With Quote
Old 04-19-2015, 09:51 PM   #7
Jayred
I had the same issue but I gave up and bought an aluminum hose kit. It was $70 but looks great. Cut to fit, easy as pie.
Jayred is offline   Reply With Quote
Old 04-19-2015, 09:56 PM   #8
74baggedbug
Gates 20694 is the lower radiator hose
74baggedbug is offline   Reply With Quote
Old 04-19-2015, 09:59 PM   #9
dirtyjim
dirtyjim's Avatar
autozone Part Number: E70664
when you look at the hose it looks like there is no way it will fit but it does
Old 04-19-2015, 10:15 PM   #10
wbc409
Both Dayco and Gates have a catalog that has a picture of the hoses based on hose inside dia. It's getting harder to find a parts store where they are willing to break out the books though.
wbc409 is offline   Reply With Quote
Old 04-20-2015, 12:50 AM   #11
Clavo106
I would go universal.or modify the radiator.. my c10 has a c20 3/4 chassis that someone chopped the springs way to low. it bottoms out. the lower rad hose douse hit the frame but they put a rubber piece on the frame to protect the hose from rubbing....good luck.
Clavo106 is offline   Reply With Quote
Old 04-20-2015, 09:41 AM   #12
cdowns
cdowns's Avatar
go to local autoparts store and get a lower hose for 71-72 walk outwith it take home and install
Old 04-21-2015, 12:55 AM   #13
kcsa75
kcsa75's Avatar
http://www.oreillyauto.com/site/c/de...0097&ppt=C0075
I put this hose on my truck on Sunday afternoon. It is a cut-to-fit as Dirtyjim said. Fits like a glove. You should be able to find it at any parts store.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-21-2015, 03:08 PM   #14
csfields
csfields's Avatar
Ran into the same situation with my radiator. Get the AC Delco AC24053L off Ebay for 13 bucks. Did some small trimming and it fit perfectly.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 04-21-2015, 06:47 PM   #15
gearheads78
OK I don't know if they changed the design or what but the pictures show its at 90 degree off the water pump. Before I have made this post I had already tried both the Autozone and Gates parts mentioned. Both are molded aprox 45 degrees and would ride right on the frame. The V6 one that used to be in the truck was shaped like the template I made so I assumed the correct one would be also.
That looks like it will work. Thanks a ton!!
Old 04-21-2015, 09:14 PM   #16
dirtyjim
dirtyjim's Avatar
not the best pic but the hose comes off the water pump and rides the top of the frame down. the hose in post #14 is for a later model truck but they work too
