Old 07-21-2015, 11:15 AM   #1
Mator
Mator's Avatar
Why is it so hard
Why is it so hard to get information about 6 lug rims? Rallies are great and so are steelies but I want shinny. Chrome or polished. I have searched and still can’t find the answer. I know others have asked too with no luck too. I thought I had back spacing figured out and when I started talking to wheel companies they asked about offset which proceeded to blow everything I thought I knew out of the water. I am sure there is a lot of different choices on front, back, back spacing, width, diameter and offset. I am just really frustrated on my search for a tire wheel combo that won’t cost more than I paid for the truck. Can anyone help me out? Looking for a good set up for 20’s with a 6 lug for a 67 step with a 3-6 static drop. I don’t have a retailer close so I have to order them and have them delivered so I get only one shot at this. Thanks for listening.
Mator is offline   Reply With Quote
Old 07-21-2015, 11:29 AM   #2
michael bustamante
michael bustamante's Avatar
Re: Why is it so hard
did you do the disk brake conversion yet?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-21-2015, 12:23 PM   #3
Mator
Mator's Avatar
Not yet.
Old 07-21-2015, 12:42 PM   #4
Mator
Mator's Avatar
So below is what the last company sent me and it seems odd. I know during my search's most guys are running 4.5 -5 backspacing
"Ok, so here's where we're at. The Torque Thrust would just be an option in 20" with a chrome finish for your truck. The issue with those though is concerning the offset. The lowest offset they are available in for this fitment is with a positive 19 offset. Your Chevy has basically a very low, or negative offset. Long story short, that positive offset would sit more inward than the stock wheels do, meaning you'd have to run a spacer along with it to get it pushed back outward"
Old 07-21-2015, 02:29 PM   #5
scotts72heavyhalf
scotts72heavyhalf's Avatar
Here is a 6 lug option hood for you. JR5's from Hot Rods By Boyd. Come in painted or polished and in any size you need. The guys at HRBB are super helpful.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 07-21-2015, 02:29 PM   #6
scotts72heavyhalf
Another
Scotts72C10
Old 07-21-2015, 11:47 AM   #7
colgad
colgad's Avatar
This may help you out some.
https://www.customwheeloffset.com/ti...et-calculators
It took me a while to get the offset thing in my head but this calculator really helped me. I have 20's on my 67 fleet that are 10" wide front and rear. 275x45 tires The rims are both 0 offset making the hub basicly in the center of the rim. I got the rims cheap so I decided to make them work. With this calulator you can see what difference a change in offset does to the distance from the rim to the inside and the out side of the rim. You can also change the width and see what difference it makes. With my setup I had to add a 1.5" steel spacer to the rear and nothing in the front. My rims are closer to the outside of the fender than i would like but there is nothing rubbing so I am happy. I have bags and dropped spindles making the total drop in the front about 3-4 and the back 5. Nothing radical it's just what I like. Hope this calculator helps you to understand the + and - offset and what effect it has on backspace.
Here;s my 67
http://67-72chevytrucks.com/vboard/a...ictureid=20684
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-21-2015, 03:52 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
The problem that you're running into is that 6 lug wheels just aren't that popular for classics.
They are, however, popular for new trucks as GM has been 6 lug for quite some time, but as your finding out, most 6 lug wheels have a lot of positive offset as they're meant for newer trucks (look at any modern Silverado and see how close the hub is it outside the wheel), so as mentioned by the wheel seller above, you would need a spacer with most 6 lug wheel choices.
Terrible wheel selection for 6 lugs is why most of us go with the corvette or truck style rally wheel... or swap to 5 lug.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-21-2015, 05:12 PM   #9
colgad
colgad's Avatar
Those Boyd's wheels are really nice but they are pricey! 900+ for each wheel throws most of us out of our comfort zone.
Old 07-21-2015, 06:05 PM   #10
Mike C
Mike C's Avatar
Another reality for the late model 6 lug wheels is that the hub pilot hole is too small for these early trucks that have the same hub diameter as the 4x4. This is another reason people uses spacers.
While a little more work up front, for me, the switch to 5 lug at the time I did the disc conversion was a no brainer. Made buying wheels relatively easy and increased the choices exponentially.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-21-2015, 09:30 PM   #11
Mator
Mator's Avatar
Those are nice rims but again I didn't pay that much for the whole truck,even if I am in the process of retouching everything on it. I was trying to keep the feel of the 67 with a touch of new. There has to be something out there that work and looks good. I just have to keep searching I guess.
Old 07-21-2015, 10:28 PM   #12
colgad
colgad's Avatar
CPP has a 5 lug rear axle conversion for 67 for under $400 part number 6569RACK
Go with a 5 lug disk conversion and you ahead that way too. 6370SWbk-5 for around 800
Old 07-21-2015, 10:46 PM   #13
Mator
Mator's Avatar
This is a nice upgrade but was hoping to do this later and keep the 6 lugs. I found a :78 donor truck and can get the front end and rear end for 400 bucks. But again didn't do it.
Old 07-22-2015, 05:11 PM   #14
rharp
I researched this long and hard with my 69. I could never find a wheel I truly liked for a price I was willing to spend. I ended up just swapping a 72 front and rear end out and making it 5 lug. It's just too easy to find nice wheels in the 5 lug pattern.
1969 Chevy CST/10 396, PS, PB, A/C
rharp is offline   Reply With Quote
Old 07-22-2015, 08:07 PM   #15
Mator
Mator's Avatar
I' not giving up just yet.the I am close but I have looked at the wheels from the site in the second post and might have a winner. If that falls through I will upgrade to 5 on 5. Is that the right bolt pattern?
Old 07-22-2015, 09:12 PM   #16
rharp
That's the one
Old 07-22-2015, 10:01 PM   #17
Mator
Mator's Avatar
How about these? Will 20x9 0 offset and 20 x 10 -19 offset work?
https://www.customwheeloffset.com/bu...-0-custom-rims
Old 07-24-2015, 11:41 PM   #18
Mator
Mator's Avatar
So I found a good deal on Rocket booster 6's. But they only come in 20x9 with 5 back space and 20x9 5.75 bacspace. What's the best choice? Looking at 275/45/20.
Old 07-25-2015, 09:43 AM   #19
colgad
colgad's Avatar
So I found a good deal on Rocket booster 6's. But they only come in 20x9 with 5 back space and 20x9 5.75 backspace. What's the best choice? Looking at 275/45/20.
I would use the 5" Backspace ones (0 offset), you may need 1.5" spacers for the rear to get the rims closer to the outside of the fender for looks.
My rims are 10" with 0 offset and I would like more backspace in the front but the ones you are looking at are 9" and would give you .5" more clearance than mine (when you go to disk). The 5.75 backspace would give you 1.25" more clearance than mine.
If you are going to change to disk, in most kits it moves the spindle out .75" so the 5.75" backspace rims would offset (no pun intended) the addition of disk spindles. CPP has no offset disk kits by the way, then you could have all the same size rims.
Old 07-25-2015, 10:06 AM   #20
Mator
Mator's Avatar
Thanks. I was hoping someone could help. I start with the 5's and adjust the back as needed.
Old 07-29-2015, 10:19 PM   #21
colgad
colgad's Avatar
I have bags all around so hard to say the exact drop but I like to run with the top of the tires at the top of the wheel wells most of the time.
looking forward to photos with the Boosters!!!
I installed a soft top on my Jimmy today, it was pretty easy. I just got the 5.3 running and may take it for a drive tomorrow, if the rain stops.
Old 07-29-2015, 10:46 PM   #22
Mator
Mator's Avatar
Wow, nice rig. Thanks again
Old 07-30-2015, 12:01 AM   #23
colgad
colgad's Avatar
Thanks, it's rust free but not very straight, I bought it with a bad 350 so I had a 5.3 and swapped it in. It will be just a runner for the beach, fishing and hauling around the grandkids.
Old 08-10-2015, 07:54 AM   #24
Mator
Mator's Avatar
Well, I pulled the trigger and they are in. What do you think. I think they are awesome. Rocket booster 6's 275/40/20. They were out of the 45's. and yes I have center caps.
Old 08-10-2015, 01:10 PM   #25
bigmac73
bigmac73's Avatar
what paint color and brand is that , I am digging it but not trying to copy
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
