Old 08-04-2015, 10:51 PM   #1
60ChevyFTC
Question Matching Torsion Spring Height Help
Can anyone with more experience than me please tell me if there is a way to make sure that the driver and passenger side torsion bars are adjusted to the same height? Can i just count the bolt threads? Should I take the bolts all the way out and tighten again counting the revolutions? Any help would be appreciated.
60ChevyFTC is offline   Reply With Quote
Old 08-05-2015, 12:39 AM   #2
slepysal
slepysal's Avatar
Re: Matching Torsion Spring Height Help
When I lowered my 60 I jacked it up and counted the same amount of turns on one side then did then turned on the other side to match. Make sure to soak the bolts with PB blaster before
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-05-2015, 04:37 PM   #3
forestb
forestb's Avatar
I agree and you can easily adjust a little afterword if one side is higher than the other.
forestb is offline   Reply With Quote
