12-17-2015, 10:25 PM | #1 |
1981-83 chevrolet 3/4 ton rear brakes?
I'm looking for the rear brakes off of a 1981-83 Chevrolet 13 inch rear drum brakes on a 3/4 ton truck or suburban with a semi floating rear end. Here are pictures of the drums and backing plates that I'm looking for. They are mounted on a 1952 Chevrolet 3/4 ton full floating rear axle. I'm going to use them to convert the rear brakes on my 1946 Chevrolet 3/4 ton. What are the part numbers for the brake backing plates for a 1981-1983 Chevrolet 3/4 ton with a semi floating rear axle with 13 in drums?
12-19-2015, 12:38 AM | #2 |
Re: 1981-83 chevrolet 3/4 ton rear brakes?
I can't help but WELCOME to the board.
There is a lot of good and knowledgeable guys here. Going to tell you now we love pics. Regardless of condition. |
12-19-2015, 12:49 PM | #3 |
Moderator
Semi Floating 14bolt with 13" brakes (JB7 JD7)
1981-84 "CKP2" - 1983-84 ' G3 REAR AXLE-9 1 /2 " DIAMETER RING GEAR 5.001 PLATE, Brake Flange PLATE. Rr Brk Flg-LH (13 x 2 1/2" Brk) (JB7, JD7) .... 355881 PLATE. Rr Brk Flg-RH (13 x 2 1/2" Brk) (JB7, JD7) .... 355882
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-19-2015 at 02:41 PM. |
12-21-2015, 03:32 AM | #4 |
Where did you find that information? And those numbers are the for the backing plates in the pictures.
12-19-2015, 01:15 PM | #5 |
Moderator
This is not the axle you were requesting. But it looks more like the unit in the pictures with the addition of Disc brakes.
How bout a 77-81 P30 11,000lb rear axle with the JF9 four wheel disc brakes option. This axle has 13.75" x 1.53" rear Disc Brakes. The spring perches are narrow like the squarebody Cab & Chassis Dana 70 dually axle so bring your tape measure.
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-21-2015 at 06:00 PM. |
12-21-2015, 11:55 AM | #6 |
Moderator
You stated "rear brakes off of a 1981-83 Chevrolet 13 inch rear drum brakes on a 3/4 ton truck or suburban with a semi floating rear end."
I Believe this fits the bill... 9 1/2" axle (14bolt semi-floating axle) from 1979-1984 Illustration book... The part #s came from the 79-84 GM parts books. Look in the 1973-1991 manuals link in my signature and page down toward the bottom of the first post. You need a pair of books for each year group... the illustration and the parts books. The PDF files are 30-70 meg each. You use them as follows.
Semi Floating 14bolt with 13" brakes (JB7 JD7) 1981-84 "CKP2" - 1983-84 ' G3 REAR AXLE-9 1 /2 " DIAMETER RING GEAR 5.001 PLATE, Brake Flange PLATE. Rr Brk Flg-LH (13 x 2 1/2" Brk) (JB7, JD7) .... 355881 PLATE. Rr Brk Flg-RH (13 x 2 1/2" Brk) (JB7, JD7) .... 355882
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-21-2015 at 02:20 PM. |
12-21-2015, 05:18 PM | #7 |
I have a 1981 3/4 ton semi floater,with 13" brakes out of my suburban,I changed it out for a full floater,I would give it to you,just need to pay for shipping
12-21-2015, 08:35 PM | #8 |
12-22-2015, 01:32 AM | #9 |
12-31-2015, 04:33 PM | #10 |
Bump back up to the top still looking for the parts
12-31-2015, 05:00 PM | #11 |
Moderator
Late 80's & 90's G20 & G30 vans and some C2500 pickups had the 9 1/2" 14bolt axles. Take a walk in the local pick-a-part.
And please let us know if and how your repairs were successful. |
12-31-2015, 07:51 PM | #12 |
I did that yesterday the oldest GM truck in the you pull it yard was 1990.
12-31-2015, 07:18 PM | #13 |
That's your best answer, walk the yards. My semi float rear brakes fit my full floater.
12-31-2015, 11:35 PM | #14 |
Moderator
The 3/4 & 1ton G20 & G30 vans and the GMT400 88-98 CK HD 1500 & LD 2500 through the late 90's used this axle but the backer plates don't have the same part #s as the early 80's units. If they have 90's trucks you will probably find what you want.
EDIT... Sorry.. If the early 80's SF 9.5" 14bolt 13" backer plates are what you need... your only plays are to luck into some dusty boxes on some dealer's shelf or get em used. Either means some legwork. The FF & SF have different part #s. I provided information based on what was requested. If the FF axle parts will work then you can buy em new. They are in the parts books and they are still available. Look em up.
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-01-2016 at 04:18 PM. |
01-01-2016, 03:28 PM | #15 |
Umm, did I miss something? I was trying to give the OP somewhat of an option and inform him that the plates can fit semi and full float rears.
Ohhh, now I see after reading my post, it could have been taken out of context. I was agreeing with your post that walking the yards would be the best way to find what he was looking for. |
01-01-2016, 04:12 PM | #16 | |
Moderator
01-01-2016, 06:28 PM | #17 |
We've all had those days, not to worry!!!
