tommy217xxx Steering column question 01-12-2016, 01:38 PM
tommy217xxx Re: Steering column question 01-12-2016, 06:25 PM
tommy217xxx Re: Steering column question 01-12-2016, 09:25 PM
tommy217xxx Re: Steering column question 01-13-2016, 12:58 AM
hatzie Re: Steering column question 01-13-2016, 08:47 AM
tommy217xxx Re: Steering column question 01-13-2016, 10:08 AM
tommy217xxx Re: Steering column question 01-13-2016, 11:09 AM
slotard Re: Steering column question 01-13-2016, 02:37 PM
hatzie Re: Steering column question 01-13-2016, 05:31 PM
tommy217xxx Re: Steering column question 01-14-2016, 12:49 AM
hatzie Re: Steering column question 01-12-2016, 09:55 PM
hatzie Re: Steering column question 01-12-2016, 10:22 PM
01-12-2016, 01:38 PM | #1 |
Hey everyone, I have a tilt column out of a 77 and I want to put it in my 76. I need to replace a seal on the intermediate shaft. Ive already removed the clip but I can't figure out how to get the seal out.
Also does anyone have a part number for this seal?
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
01-12-2016, 06:25 PM | #2 |
Any one got a link. I tried to find with the search feature and no luck.
01-12-2016, 09:25 PM | #3 |
Mines already torn. That's why I'm taking it apart.
01-13-2016, 12:58 AM | #4 |
The link with the disassembled lower worked out. I found that by putting a straight slot screw driver in the slots in the ends and working each side down little by little. I actually have 2 columns. One with a good boot and one with a bad one. I need the top on the one with the bad boot on it. So I just swap tops and install the new tilt column. I would like to fine a seal but it sounds like there pretty hard to find. I read some where that early chevelles used the same column. So I'm gonna dig a little. I stopped by a Chevy dealer and there parts computer goes back to 82. Any one know if they used the same boot/column in 82?
01-13-2016, 08:47 AM | #5 |
Moderator
Download the 73-78 & 79-84 truck parts books...
I believe Ian Harding has the Chevelle parts books on gmpartswiki.com
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-13-2016, 10:08 AM | #6 |
I just stopped at the dealer and they said it was discontinued for like 10 years.
01-13-2016, 11:09 AM | #7 |
I would go the jeep route if I didn't already have another shaft and boot. I'm just gonna swap the caps and call it good.
01-13-2016, 02:37 PM | #8 |
I ought to go with an XJ shaft on mine, guess I should find one in a junkyard and hope it still has what I need. My steering isn't great.
1973 C20, 350/350 |
01-13-2016, 05:31 PM | #9 |
Moderator
Go to Car-Part.com and look up Jeep Cherokee 1984-2001 (XJ chassis)... The part you're looking for is the "steering coupler".
Borgeson sells raw steering shaft parts to roll your own... telescoping steering shafts and single row needle steering universals. They're kinda spensive tho...
01-14-2016, 12:49 AM | #10 |
I just took the good boot apart and it came apart a little differently. I oiled the boot all the way around where it sits in the coupler just I didn't rip it. Then I used the shaft like a slide hammer. A few little slides and it came right out.
01-12-2016, 09:55 PM | #11 |
Moderator
I did one in my 76. No looking back. Just do away with the original shaft entirely. Far tighter than the new rag joint on my CUCV.
01-12-2016, 10:22 PM | #12 |
Moderator
Other than the Doghead starter relay mod I've tried to keep the M1008 original. For some reason the unmolested CUCVs seem to be desirable. Otherwise She would have an XJ shaft and an SM465 with a Gear Vendors OD and gauges.
The new rag joint tightened up some of the slop on my CUCV but not as much as the XJ shaft in my 1976.
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-13-2016 at 08:48 AM. |
