Old 01-15-2016, 09:33 PM   #1
Sandtrap9072
Sandtrap9072's Avatar
1972 Gmc Jimmy Wire Identification
So, I am cleaning up some wiring in the engine compartment and came to a purple wire that was spliced into a red wire that runs to the starter. Can anyone tell me what their purple wire runs to, this doesn't seem right? Please see attached pictures. Also, where the red and purple wires are spliced, there is a green wire and a black wire that are cut, does anyone know where these are supposed to run to? Any help would be greatly appreciated.
Sandtrap9072 is offline   Reply With Quote
Old 01-15-2016, 10:55 PM   #2
jaros44sr
jaros44sr's Avatar
Re: 1972 Gmc Jimmy Wire Identification
sandtrap, not to put you off, but I don't know the answer to your question. But, I do know that if you drop down into the electrical section there is a colored wiring diagram of the entire wiring harness. I will follow along to make sure you get it sharpened out. Please post a follow up, so I can see where you ended up
To many whiskies to type
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-16-2016, 10:24 AM   #3
hemi43
hemi43's Avatar
Purple wire comes from the starter switch (hot on start) then goes to the neutral safety switch at the bottom of column,and then goes to the solenoid on the starter. My guess is that the original wire got damaged because it's near the exhaust, so the previous owner spliced in the new red wire.
hemi43 is offline   Reply With Quote
Old 01-16-2016, 10:26 AM   #4
Sandtrap9072
Sweet, thanks guys. What about the green and black wire shown in the second picture?
Old 01-16-2016, 12:33 PM   #5
hemi43
hemi43's Avatar
I tried to find out, but since my truck is a 70 it's a bit different. I have a feeling it may be for emission controls but I'm not sure, sorry.
Old 01-16-2016, 01:11 PM   #6
ls1nova71
ls1nova71's Avatar
Green wire looks like the temp sender wire. As for the black one, you'll have to trace it back and see where it goes. If it goes into the bulkhead connector, post a pic of where and we can figure it out from there. I would also trace the green one to make sure it goes to the bulkhead too, it's just with that aftermarket wire loom you never know what a previous owner could have put in there.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-16-2016, 07:28 PM   #7
87Skier
87Skier's Avatar
Mine had a TCS (transmission controlled spark) module but most of the components were missing. It came out about where you were talking about. I redid my wiring and eliminated this stuff.
Look at this link:
http://67-72chevytrucks.com/vboard/s...d.php?t=196397
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-18-2016, 01:05 PM   #8
Sandtrap9072
Thanks for all of your helps fellas, i haven't been able to make it back out into the garage lately. But when i do ill look into the black wire.
