01-26-2016, 03:20 PM | #1 |
fuel pump question for 88 model 5.3 ls swap
I'm about to do a 5.3 swap on a 88 Chevy Truck but I would like to keep the fuel pump in the tank if possible, has anyone ever done this if so what fuel pump is it that you used, part # or any suggestions would help, I don't think the tbi fuel pump will put out the pressure required for ls
01-26-2016, 03:24 PM | #2 |
Boosted Member
Re: fuel pump question for 88 model 5.3 ls swap
I've done it. You just need to swap the in-tank TBI pump with a pump from an LS truck. It should drop right into the old hanger assembly.
A stock TBI pump won't work. They only run about 12 psi, and you need 58 with an LS
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-26-2016, 07:19 PM | #3 |
Wasted income is spot on. Your 88 is a return system that can be utilized again if needed.
01-26-2016, 09:10 PM | #4 |
AC Delco ep381 should be a direct swap. I used the same fuel pump for my 5.3/4l60e swap completed on my 1987 c10. It was a tbi driver also.
01-31-2016, 01:24 PM | #5 |
Ok guys the swap is going very smooth got the fuel pump in and ready to install it, cheap to not a bad price, what are you guys doing about fuel fittings I would like to keep the existing steel braided lines that are the but they both have male ends, what fittings work?
01-31-2016, 09:57 PM | #6 |
here is what i did on the fuel lines at the motor... kept the stock tbi braided lines under the truck... and used the ls fuel lines at the engine. yes its compression fittings, and no i have never had a failure with them. i use them on alot of pressure lines with no problem.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
02-01-2016, 01:13 AM | #7 |
Where did you get that set up from?
02-01-2016, 10:48 AM | #8 |
Boosted Member
Compression fittings work great for fuel system stuff. Used them many times, never a problem.
06-08-2016, 05:02 PM | #9 |
Is this pump strong enough for a 5.3?
PERFORMANCE ELECTRIC P988K Fuel Pump Module Repair Kit Info Category: Fuel Pump $37.79
06-08-2016, 08:31 PM | #10 |
Soild i would jsut get an acdelco ep381 there like 40 buxs on ebay and work great no guessing
06-08-2016, 08:57 PM | #11 |
any link to the $40 pump ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-09-2016, 01:37 AM | #12 |
http://www.ebay.com/itm/ws/eBayISAPI...861&rmvSB=true I bought 2 of these... havent started swap yet but dont see why there would be any problems.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
06-08-2016, 09:26 PM | #13 |
Thanks Dave
I'm on it !!
06-11-2016, 02:02 PM | #14 |
Well at least the box says ACDelco and it looks the same!!!
Good service from USPS
06-09-2016, 01:45 PM | #15 |
meowMEOWmeowMEOW
The most recent review for that pump says that "they didn't send me a 381, its an inferior Chinese generic replacement pump" ....so might be worth being a little careful.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-09-2016, 04:35 PM | #16 |
Brew makes a good point ... doing a search on Amazon for the AC Delco part number brought up a fuel pump that looks nothing like the on in the ebay ad.
https://www.amazon.com/ACDelco-EP381...=1&*entries*=0 |
06-09-2016, 11:13 PM | #17 |
can you please share a link to a proper GM/delco picture of the fuel pump? I have not been able to find a gm/delco supplied photo to use for comparison against my actual ebay purchase mentioned above.
thanks
06-10-2016, 02:37 PM | #18 | |
